It is currently Sun Jul 20, 2025 3:34 am
PostPosted: Sun May 23, 2010 7:25 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Hi!
I don't know where to post it so, sorry for the double post...
I had this idea, with a friend of mine who want to start out lutherie, to create a serie of "mianiatures". In fact, a series of steel stringed electric ukus, with strat, tele, les paul, flying V shapes. Really not expensive to do (recycle some scrap wood or mill ends, etc), fun and educative, and also quite easy to sell at a reasonable price, cause ''it's so cute!''.
So, I have some questions here about the electric side of the project.
Bridge: What type of bridge should I use? Are there existing bridge for ukus or should I use single saddles, or a fix acoustic type bridge&
Tuners: I guess regular schaller mini would do it. Any other suggestions?
Pick ups: Are they existing? Or should I make special order or take trancuder or other type of pick ups?
Strings: Are they streel strings for ukus? If not, I guess regular guitare strings cutted to needed lenght would do it.
Last thing... Truss rod? Neck reinforcement? Nothing? Just more heavier neck (from hardwood, or with laminates)
Thanks!
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Mon May 24, 2010 4:55 am
First name: Martin
Last Name: Edwards
I've made electric mandos using regular tuners and a cut down strat bridge.
for pups, 1/2 a split bass pup is perfect for a mando, but a blade type of guitar pup will work for wider spaced strings.
as for steel strings on a uke, if it's electric, you have to go steel for the pups to work.
I use double acting truss rods form a tiwanese ebay seller
PostPosted: Mon May 24, 2010 7:22 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
I already tought about a bass split pick up, but, a bass range pick up for a ukulele who's quite high... i'm note sure of the quality of the sound. Maybe a soapbar could be ok, but it's really to large... maybe if I put it with an angle... near the neck at bass, and closer to the bridge at trebble.
PostPosted: Tue May 25, 2010 8:06 am
First name: Martin
Last Name: Edwards
range?
you'd be surprised!
the split bass pup is GREAT on my mando strat
PostPosted: Tue May 25, 2010 8:20 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Wich one you took?
PostPosted: Wed May 26, 2010 4:16 am
First name: jon
Last Name: letts
City: leicestershire
Zip/Postal Code: le676pz
Country: uk
ive considered doing a similar thing with two string piccolo basses shaped like rubber chickens )) i decided that to keep the cost down and therefore produce a cheap novelty/fun instrument, i would have to start making my own pickups. there are some really cheap homemade cigar boxx pickups on ebay that would definately work. but as i say, they look real simple to make yourself so i reckon thats the way to make this venture pay off.
PostPosted: Wed May 26, 2010 9:31 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
I think i'll consider to make my own pickups... try to find an little motor and a digital counter to make my own winder...
PostPosted: Sat May 29, 2010 12:03 am
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
If you use P bass pickups you get a humbucking pair for the price of 1 pickup.
How long is that in luthyears?
PostPosted: Wed Nov 17, 2010 7:10 am
First name: jon
Last Name: letts
Country: uk
i now have a friend making pickups for me! they sound awesome and he's coming up with some really cool ideas. rails, air coils and stuff. the winder is a hand drill and he made a counter using a magnetic switch wired up to a modded calculator. the switch is wired to the = button. tap +1 into the calc and every turn hits the =. we're getting accurate readings and about 6000 turns, tapped coils and all the benefits of scatterwound pups at half the price of a factory emg.
