It is currently Sat Jul 19, 2025 4:09 am
PostPosted: Fri May 21, 2010 6:20 am
First name: Frank
City: Saranac Lake
Howdy all. Building a 12 electric neck through Maple/mahogany neck I will be using Hot Rod truss from Stewmac (http://www.stewmac.com/shop/Truss_rods/Adjustable_truss_rods/Hot_Rod_Truss_Rods/1_4_Hex_Nut_Hot_Rod.html)
Will I need additional reinforcement from either carbon fiber rods or double rod it (being a cheaper alternative)?
Build it cause then you know it's Made in the USA or **insert your country**
PostPosted: Sat May 22, 2010 7:40 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
In my opinion, this standart trussrod will do it. The 6 additionnal string have small gauges, so they don't pull the neck that much ( 12 strings is not double tension of 6...). I think a simple truss rod is enough to resist the tension. Maybe you could take some assurance by doing a stiffer neck (with some harder wood laminates), and, obviously, with a really well quartered neck, that will be more stable (I didn't say stronger, don't start the debate again!)
My two cents!
By the way, I love 12 stringed electric, you have more details on you project?
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat May 22, 2010 8:41 am
First name: Frank
City: Saranac Lake
Haha yeah I have details sort of a frankenstien build.
Chambered body with neck through. Narra (asian rosewood), maple back, spruce top. Maple/African Mohagony laminate neck rosewood fb. Thinking LP scale. I'm debating on the satriani pickups I like em very versitile sound but unsure on feedback with a chambered. I'll get some pics going here soon.
PostPosted: Sun May 23, 2010 3:24 am
First name: Martin
Last Name: Edwards
+1 regular rod'll be fine.
PostPosted: Thu Jun 10, 2010 9:56 am
When I built my electric 12, I duplicated the dimensions of my Takamine 12-string acoustic (nut width and back profile) but made up the neck blank of quarter-sawn maple with Bolivian rosewood accent stripes. It's a 24-fret neck. I used a double-action truss rod from W D Music. No additional reinforcements, and the neck has been stable for 5 years. After the initial setup, I've never touched the truss rod.
--Steve
PostPosted: Sat Jun 12, 2010 9:09 pm
First name: Frank
City: Saranac Lake
Thanks for reply Steve.
I have decided to go with the hot rods and considered I am using good quater sawn maple.
Will try to get pictures posted of progress but I just get so absorbed in the work I sort of forget.
As far as neck since I have the bridge and black tusq nut I based my neck dimensions on that.
Though here's a pic of me with my brother-in-law and nephew dragging a white spruce for some future guitars.
