It is currently Tue May 13, 2025 11:59 pm
 Post subject: Bridge positionning
PostPosted: Mon Feb 01, 2010 9:28 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Yup yup!
I was marking down bridge and pickups locations on my bass today, before to rout them. I bought a fender style neck, 20 frets, 34'' scale. So I take my straightedge and tape and mesure 34 inches from the nut, having in head the idea of the future compensation. 34'' brang me way down the body, almost. So I learned that fender announced scale are compensated scale (for the bigger string). So what's the best way to locate the bridge emplacement? I know there almost ½'' of possible ajustment on a electric bass bridge, so it's not critical, but, i want to make it right.
Thanks!
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
 Post subject: Re: Bridge positionning
PostPosted: Mon Feb 01, 2010 11:33 pm
Others here have probably got more fancier ways of doing things, but what I do is mount the neck, take a measurement from the fingerboard side of the nut to the center of the 12th fret. Adjust the highest saddle(in the case of a 4 string, the G string) most of the way forward in it's travel(toward the nut),then place the bridge on the guitar and position it so that the distance from the center of the 12th fret to where the string will break over the G string's saddle is the same as the distance from the front of the nut to the 12th fret. That will get you into the ball park. The string will probably intonate a little farther back from that.
PostPosted: Tue Feb 02, 2010 12:16 am
Last Name: Abercrombie
Or take a tape measure to the music store, if you have a good one nearby.
Make sure the Fender bass in the store plays in tune before you measure, though!
PostPosted: Tue Feb 02, 2010 12:47 am
That's assumimg the guitar he's building or the body he's got has the same neck pocket length and geometry of the Fender. If not, those measurements won't help much.
PostPosted: Tue Feb 02, 2010 7:04 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Thanks Mike, that's what i was thinking to do... mesure the real scale, put the bridge at his highest point, and them compensate... thanks1
