It is currently Wed Jul 16, 2025 2:08 pm
 Post subject: Need re-assurance
PostPosted: Mon Mar 24, 2008 3:24 am
City: Jacksonville
Well...since haste is a by-product of excitement....I got hasty....
I think I can continue with this...but I just need to be extra careful. This top has ALREADY been thickness sanded to .095 +/- .002......AND.....I already cut the soundhole and profiled it to rough shape.
gaah gaah gaah
Saving Graces?...my drill press has a table set up with a locator hole (in the table) for my circle cutter and it hasn't been touched so it's still set up.
So do I just need to be REALLY CAREFUL?...or start over?..FYI...I am still going to try even if you say.."Uhhhh Yeah...go buy a new top...yeah that's it!" pfft
 Post subject: Re: Need re-assurance
PostPosted: Mon Mar 24, 2008 5:15 am
I assume you're talking about not having a rosette channel cut. I expect it to be difficult, but not impossible, to do. I would use a dremel with the Stew-Mac guide.
http://www.stewmac.com/shop/Tools/Special_tools_for:_Binding/Purfling_Soundhole_Router_Guide.html
PostPosted: Mon Mar 24, 2008 5:20 am
City: Keene
If you still have the cut out, you can pop it back in.
PostPosted: Mon Mar 24, 2008 5:22 am
City: Jacksonville
An update....I found the piece that was cut out (soundhole) lying on the shop floor and managed to 'mate' it back up with the top. Consequently I should be able to line it back up to the drill press fairly easily.
No matter what tool, dremel or otherwise, my perceived problem is being able to find center again. I may have an entirely different problem I don't know about....so if I do please let me know...
Ron what'r you doin up this early.....I couldn't sleep cuz of this issue with the top.
PostPosted: Mon Mar 24, 2008 6:29 am
Why don't you put a binding around the inside of the soundhole and forget about doing a rosette.
If you want to see what it looks like have a look at Paul Woolson's website. He's the master of this and if you search through the archives you'll find a tutorial from him on how to do it.
They do look good and it may be a very simple way of fixing this.
Bob
Bob Connor
Geelong, Australia
PostPosted: Mon Mar 24, 2008 6:46 am
First name: Jim
Last Name: Kirby
Sniggly, it sounds like you need a checklist for order of operations, and a promise to yourself not to violate it anymore.
Believe me, I'm not trying to be rude. I'm guilty of having glued the back on a spanish-heel classical guitar without setting the neck angle first, so I know how bad getting things out of order can get. gaah gaah
(and another few in Hesh' honor gaah gaah gaah gaah gaah )
Jim Kirby
kirby@udel.edu
PostPosted: Mon Mar 24, 2008 9:38 am
I would make up a cross grain patch that will fit between the X brace and the transverse brace.
Glue that to the inside of the top then carefully re-glue the cutout back in to re-establish your center point.
Redrill and off you go. If you are not perfectly centered you can make the soundhole very slightly larger after you do the rosette work.
Keith MacKenzie
"To err is human to really screw up you need tools"
PostPosted: Mon Mar 24, 2008 12:03 pm
When you get old, you wake up at all hours. wow7-eyes
BTW, the Stew-Mac attachment is made for this, and it doesn't matter where the center is. It just guides off the sound-hole edge.
PostPosted: Mon Mar 24, 2008 8:23 pm
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
You could be avant garde and do an off-center rosette! Intentionality can offset what some may call a mistake but others call an opportunity................. :D
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Mon Mar 24, 2008 8:42 pm
95 thou is kinda thin. What size guitar are you making?
PostPosted: Mon Mar 24, 2008 8:56 pm
City: Jacksonville
Howard this is an OM...Scott Antes plan.....first guitar build for me. The plan calls for 94 thou. Geeeeezzz I wish I had thought of just simply typing 'thou' instead of 'thousandths'. I am about to post some pictures of my work so look for that new post shortly.
PostPosted: Mon Mar 24, 2008 9:18 pm
I think Todd has the best answer here. Cut a fresh disk with a center hole in it that fits really nice and locate off of that.
PostPosted: Mon Mar 24, 2008 10:05 pm
I'm with Todd on this one. That should work fine. Once you level the rosette and finish sand you'll have a mighty thin top for an OM. Might just want to make a simple one ring rosette to minimize leveling.
Terry
PostPosted: Mon Mar 24, 2008 10:17 pm
City: Jacksonville
check the new post by me...I got it done...took all day...scared to death to measure the top though...
PostPosted: Wed Mar 26, 2008 10:23 am
Has anyone ever seen or heard a guitar built by Scott Antes? Googling him I find no evidence of any guitar building; just plan drawing.
PostPosted: Wed Mar 26, 2008 11:54 am
Nor have I Howard and I have surched before as well.
Users browsing this forum: Bing [Bot] and 31 guests
