It is currently Sat Jul 19, 2025 7:46 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
PostPosted: Sat Mar 22, 2008 9:01 am
City: Grandfalls
State: Newfoundland
I have used cumbersome clamps in the past and found it slow and a pain to clean up squeeze out...On my last Irish Bouzuoki I tried something different....A lot of you probally use this method but I have not seen info on it...I aligned my bridge to the exact position and using a center punch I made a centering dent in the soundboard through one of the E string peg holes. I drilled a 3/16" hole in the soundboard...Placed my bridge in place and inserted a peg to hold it in place....double checked my alignment...then drilled the second hole through the other E string peg hole......With the bridge in place and the pegs in both E string holes I checked the alignment again...I lightly scribed around the bridge and removed the finish underneath...I made my go bar deck top higher ( to allow for the dept of the Bouzouki)and used go bars to apply the pressure on the glued up bridge...With the pegs in place the bridge could not move and the squeeze out was easily removed with a wet Q-tip....I could easily check and see if the bridge was making good contact and apply more go bars where needed.....Maybe a support block under the bridge plate might be a good idea also.....Worked great.....Larry
PostPosted: Sat Mar 22, 2008 9:05 am
I use a fox style clamp which I made myself. Easy, cheap, works great.
PostPosted: Sat Mar 22, 2008 10:38 am
For gluing bridges I properly locate the bridge and then drill two small holes in the corners of the saddle slot through the bridge, top, and bridge plate. My clamping caul is spaced for these holes and you will see this in the pics. I use the steel locating pins and drill bit set from LMI for this. Now my bridge can be pinned in place.
Next I warm my bridge, get my HHG pot going and usually visit the OLF while waiting for the glue to get hot. Once my HHG is around 140Fish and my bridge has been warmed (I use a high intensity light) I insert one pin through the bridge and paint up the bottom side with HHG. I quickly position the distended pin.... in the hole in the top of the guitar and lower the bridge in place. The second pin is quickly pressed through the other hole in the other corner of the saddle slot and then my Stew-Mac clamping caul (modified with two holes for the steel registration pins) is placed on the bridge.
Lastly the two long reach C clamps are positioned as shown below, tightened, and the wing adjustment knobs on the clamping caul are set. Once it is all clamped in place I wait a minute or so for the tack of the HHG to take and then the registration pins, which are proud of the holes in the clamping caul, are pulled.
Cleaning up the HHG squeeze-out is fast and easy after a 5 minute wait and with a bit of hot water from the glue pot. I don't tape anything.
Prior to using any glue I always do a dry run and preposition what I will need for easy reach. I can do this process, live with HHG, in under 15 seconds.
Here are some pics:
PostPosted: Sat Mar 22, 2008 10:50 am
I used the Dam Tape, I mean Tape Dam method, and a homemade jig similar to the one Hesh showed. Seemed to work just fine.
PostPosted: Sat Mar 22, 2008 11:02 am
I pin the bridge too with 1.4mm finishing nails in the saddle slot that fit great in a 1/16 drill hole. Hide glue with the Stew Mac caul and a long reach clamp.
I remove the finish with the router method, and leave a 1/32 rim of finish. I've been routing a little rabbit in the bridge edge the same thickness and width as the ledge of finish like David Collllins showed a while back.
Terry
PostPosted: Sat Mar 22, 2008 11:20 am
Last Name: O'Melia
City: Huntsville
State: Alabama
This is one of those threads that should be made sticky... VERY informative!!
PostPosted: Sat Mar 22, 2008 11:24 am
It's a mistake to clamp in a go bar deck without a solid block inside, and it would need to be fitted to the arch of the top (and back).
PostPosted: Sat Mar 22, 2008 11:25 am
PostPosted: Sat Mar 22, 2008 12:28 pm
I have to agree with our "Guest". I have wanted to use go-bars to clamp bridges but there simply isn't an easy, effective way to support the top sufficiently. We take great pains to shape the bottom of our bridges to conform exactly to the shape of the top. Sufficient gluing pressure applied by way of go-bars would certainly change the arch in the top. It seems unlikely that the shape of the bridge would change in the same way & your care in making a precisely fitted joint is wasted.
Then, there's the real possibility of a slipped go bar & a huge dent in your soundboard... Too scary for me.
I use two 1/16" alignment pins in the saddle slot & a vacuum clamp. Works slick & is quick enough to have the HHG under full clamping pressure in seconds. After 8 - 10 minutes, I remove the clamp just long enough to clean up the squeeze out.
PostPosted: Sat Mar 22, 2008 12:38 pm
I made a couple of cam clamps that have an extended face on the bottom part of the clamp. This allows the cam clamp to be used without a caul on the inside of the box.
I use the same method of putting down a waide strip of blue tape and drawing the outline of the bridge in the exact position, then cut out the bridge with an exacto knife. Once the finish is removed, I remove the remaining blue tape and glue down the radiused bridge using the cam clamps mentioned above. The only squeeze out part that may cause a problem is the section under the cam clamps, but I have found that a damp q-tip easily works.
PostPosted: Sat Mar 22, 2008 1:30 pm
City: Duluth
State: MN
Vacuum!
-Dennis
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Sat Mar 22, 2008 3:55 pm
ToddStock wrote:
Tape to register the front edge and sides, SM clamp modified for footless bridge clamps, HHG. Quick, no issue adjusting position if the final tweak on the neck moved the body fret in a bit, and the tape reduces cleanup a bit. Trying out the new Gator green tape next time around - supposed to be 21 day safe mask on all surfaces, so a better bet than the 3M blue that some report problems with on lacquer.
That Gator green tape is better than the blue 3M. I loaded up on a few rolls a while back and am impressed with it.
PostPosted: Sat Mar 22, 2008 4:40 pm
I want to second that, on top of the fact that Daniel agreed with it as well. This might have worked with a small body (bouzouki) but it would most certainly deform or might even damage the top of a larger guitar.
I personnally use a home made Fox type bridge clamp, similar to the ones illustrated above. It's really great to clean around the bridge, especially with acoustic bridges that do not require any standard U shape clamp going through the soundhole.
Alain Moisan
(Now building just for fun!)
PostPosted: Sun Mar 23, 2008 3:05 pm
City: Keene
I use old bridge pins to locate it and then clamp with about 4 of the stewmac mini cam clamps. I'm liking the looks of that vacuum rig though!
PostPosted: Sun Mar 23, 2008 3:23 pm
I always weld them on - keeps them from coming loose :D
PostPosted: Sun Mar 23, 2008 7:14 pm
laughing6-hehe laughing6-hehe laughing6-hehe
Is/was that the Tacoma Narrows bridge Michael?
PostPosted: Mon Mar 24, 2008 9:57 am
It sure is Hesh - Galloping Gertie! There's old newsreel footage of the collapse on You Tube:
http://www.youtube.com/watch?v=HxTZ446tbzE
PostPosted: Mon Mar 24, 2008 10:28 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Bob Garrish vacuum bridge clamp!!!!! Fast, tight and can't be beat
PostPosted: Tue Mar 25, 2008 1:08 pm
DennisLeahy wrote:
Vacuum!
-Dennis
Dennis,
That looks like a Tim Burton bridge 8-) Lovely lips.
PostPosted: Tue Mar 25, 2008 1:10 pm
Fresh medium viscosity superglue direct to the well cleaned finish...
PostPosted: Tue Mar 25, 2008 1:25 pm
First name: Ringo
Once you use vacuum, you'll never go back! I use the one from LMI:
PostPosted: Tue Mar 25, 2008 1:27 pm
That seems too easy, too obvious. It can't work!
I know you've probably done hundreds that way and not had any issues, but you are obviously wrong because you just can't do that!
I'm kidding, but I'll bet you've had that reaction before, probably many times.
Is your finish catalyzed PU? Do you think it would work for any finish? (Probably a bad idea on French polish.)
I've seen you post this method before. If I saw it from someone else, I might be able to dismiss it as foolish. I can't with you. You wouldn't be doing it that way if it didn't hold up.
I suspect most of are not courageous enough to try it.
PostPosted: Tue Mar 25, 2008 1:48 pm
Steve buddy I think that Rick uses CP finishes.
I also think that I owe Rick an apology. Here's why: Some time ago when Rick indicated that he glued his bridges directly onto the finish with CA I was a jerk and took issue with this.
What's changed is that I have personally now worked with a CP finish and when chiseling off a piece, or trying to..... of the CP finish I could not get a piece off cleanly with out the CP insisting on pulling some wood along with it. My CP finish from Joe White was so firmly attached to my stinkin guitar that it occurred to me that this must be why Rick can glue his bridges directly to the finish with CA.........
I still don't know how one would remove a CAed bridge when you want to do so but most of my premature (I hate that word...) revulsion to this idea was based on knowing how tough, or not, nitro is...... and how long a bridge would stay glued directly to nitro.......
My apologies Rick.
PostPosted: Tue Mar 25, 2008 5:32 pm
At its resonant frequency!
PostPosted: Wed Mar 26, 2008 12:20 am
All I can say is that it works and it's stupidly easy...
Yes, catalyzed polyester over rosewood sealer over a coat of well dried Waterlox on the tops...and yes again, the finish sticks like glue...and you can superglue to it...and you can clean off excess superglue with superglue solvent.
RT
