It is currently Sat Jul 19, 2025 7:31 pm
PostPosted: Tue Feb 05, 2008 10:05 am
First name: Nelson
Last Name: Palen
http://www.harborfreight.com/cpi/ctaf/d ... mber=95613
Probably not enough suck, huh?
PostPosted: Tue Feb 05, 2008 11:23 am
Nelson,
Probably not, you would need to know how much suck your shop vac had though to make the decision.
PostPosted: Tue Feb 05, 2008 11:29 am
Not enough vacuum pressure would be generated. Then you need to be able to maintain the pressure at constant
PostPosted: Tue Feb 05, 2008 11:48 am
First name: Nelson
Last Name: Palen
I guess if a person could hook it up to a vacuum pump with an adapter it might make a quick&dirty setup.
PostPosted: Tue Feb 05, 2008 12:23 pm
You would need some way to insure the top and braces did not move during initiation of the vacuum. That means you need some type of fixture to hold the top and locate the braces position.
