It is currently Sun Jul 20, 2025 6:49 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 17, 2008 2:40 am
Back in the days when cars had nice curves.  Now, they all look the same.
PostPosted: Thu Jan 17, 2008 3:32 am
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
[QUOTE=grumpy]I just double-stick taped  a 48" length of 80 grit to the hood of my(then) '82 Olds Cutlass, and sanded the rails for my original, and still in use, dish. Whatever that radius is, is what I have always used....
B.Bubba: Improvise
Yes, but Grumpy, did you use enough duct tape?????????
Could you be that guy from the RE Green show?
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Fri Jan 18, 2008 9:12 am
I'm surprised no one mentioned Corel Draw. You can get a free trial version of it that will allow you to draw any/all templates and curves you want, to size, with superb accuracy. I use it all the time.
PostPosted: Sat Jan 19, 2008 5:56 am
I'm really happy to see this thread, because I'm just starting to think about my first radius dish.
[QUOTE=smdeeg]
[QUOTE=ParamesB]Here is an alternative help; http://liutaiomottola.com/formulae/sag.htm[/QUOTE]
No disrespect to R.M. Mottola (I love his site), but this tool only calculates the height at the midpoint of the chord, which I found interesting but less then what I was looking for.  I'm sure there's something else out there that will also give you points in between, but I eventually got bored looking and just did the math/wrote the program.
Actually, I think the math is the same and it seems to give the points in between if you just shorten the value of "l".  If you think about it, moving 1 inch to either side of the center is the same as shortening the length of the chord, moving it up (decreasing the displacement) and rotating it.  If you continue this process, you eventually reach l=0 which will give displacement=0.
Does anyone here have experiencewith the type of radius dish described in this link?
http://www.mcguitars.com.au/forum/viewtopic.php?t=231
It seems like an easy (and relatively dust free) method, but I can imagine problems.
Mike.
Users browsing this forum: Ken Lewis, roby and 22 guests
