It is currently Sun Nov 24, 2024 2:08 pm
PostPosted: Fri Jan 04, 2008 1:38 pm
I am currently working on a radius jig and need to know a few things. What dimensions are your fingerboards? (thickness, width at nut, width at body, scale length)
Thanks!
Brad
Avon, OH
PostPosted: Fri Jan 04, 2008 2:08 pm
For me, thickness varies but I normally start with a blank that is
~3/8" before radiusing.  Sometimes thicker if I want to recess the
truss rod into it a little.
Scale length is variable...I make both basses and guitars.
And I normally taper the board after radiusing.
PostPosted: Fri Jan 04, 2008 2:13 pm
How much taper?
Brad
Avon, OH
PostPosted: Fri Jan 04, 2008 2:30 pm
My boards are a hair over 1/4" at the center.
I use 24.9,(triple o)25.25 (archtop)and 25.4 (Dreadnout)scales.
I usually taper them 3/8" at the 12th fret.
I use a 12"radius for archtops and a 16" radius for flattops.
PostPosted: Sat Jan 05, 2008 9:39 am
Last Name: Garrish
On board thicknesses, old-school guys like Mario like thinner boards (almost down to 3/16"), most guys use 1/4" thickness, and Selmer-style guitars (Michael Collins) use 5/16". It makes sense, most production guitars I've seen these days have 1/4" thick boards, but a lot of old acoustics have thinner boards.
I like 24.5-25" scales on electrics, and 25.34" on acoustics, though I might be prone to try longer and shorter scales on acoustics for different instruments. Longer works better for the way I play chords, shorter works better for the way I play lead on acoustics.
Nut width usually just under 1.75" (1 5/8", 1 11/16")
Width at the 12th fret will be:
(nut width)+(string spread at saddle)+1/4"
                      2
That'll give you 1/8" of board above and below the strings.
Bob Garrish
PostPosted: Sat Jan 05, 2008 9:42 am
Bob...thanks for the input!
Brad
Avon, OH
PostPosted: Sat Jan 05, 2008 1:20 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Brad can't wait to see the rig. If it is like the bending and circle(rosette)tools, I bet will be outstanding.
