It is currently Sat Jul 19, 2025 11:51 pm
PostPosted: Sun Dec 30, 2007 6:25 am
Last Name: Ecklund
City: Athens
State: AL
Zip/Postal Code: 35611
On another thread, FishtownMike was wondering where to find replacement 12-string 6-on-plate tuners for a slothead. It's a lot harder to find these than it used to be and when you do they tend to be cheapies. In one of their Trade Secrets newsletters, Stew-Mac shows how to make a decent set out of mandolin tuners:
http://www.stewmac.com/tradesecrets/tuners/ts28bown/ts28bown .html
It's a good solution if you're building a new guitar, but for replacement tuners you'd want to make sure the distance between tuning posts matched your old set. You'll probably want to do that even if you find a six-on-a-plate set, as I'm not sure all those guitars used a standard distance between posts.
D..
PostPosted: Sun Dec 30, 2007 7:48 am
You can use the new individual Grover Sta-Tites to replace 12 string slot head (as on Martin D-12 20 and D-12 35) tuners. Grind back the plate tips on the units so that a single screw will secure two plates (a' la' the old Fender tuners). I suppose this would work with the Waverly tuners as well but I mention the Grovers due to their much lower price and higher gear ratio.
PostPosted: Sun Dec 30, 2007 1:28 pm
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Hey good ideas. Thanks guys
