It is currently Sat Jul 19, 2025 2:39 pm
PostPosted: Mon Dec 03, 2007 10:12 am
hey all,
at the risk of showing how novice i am at building guitars i started on an om (martin style, based on the martin plan from stewmac) project a couple of years ago and recently picked it up again. i purchased the back and sides from lmii and i can't remember the measurements that the sides need to be before i start bending. thanks to anyone that can help.
PostPosted: Mon Dec 03, 2007 10:42 am
Hey leerobs42 (Lee?)! I am building an OM now but from a slightly different
plan. It is 4" at the tailblock, and the sides are somewhere near 32", so 4
1/2" by 34" or so should be in the ballpark. Do you not have a set of plans?
If you have a set add some allowance to the finished dimensions. If not, you
need some! Good luck.
PostPosted: Mon Dec 03, 2007 11:12 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
If you have the pans take a cloth tape measure like the tailors use and measure the sides of the plan and add a couple inches to the final length to be safe.
PostPosted: Mon Dec 03, 2007 11:27 am
sweet.....what about the height of the sides? it tapers from top to bottom doesn't it? or was it 4" at the neck and 4'1/2 at the bottom? thanks, brandon.
PostPosted: Mon Dec 03, 2007 11:28 am
nevermind.....thats listed on my plan...thanks again, brandon.
PostPosted: Mon Dec 03, 2007 11:53 am
Looks like you're there but I just measured a 1931 OM, the tail block height (total, from top to bottom including back and sides of course) is 4 1/16,  neck block is 3 5/16.  Maybe that will help as well.
Bruce
Bruce Herrmann
"What lies behind us and what lies before us are tiny matters compared to what lies within us."
PostPosted: Mon Dec 03, 2007 11:55 am
Oops, should have read "including top and back" on the readings, wish we could edit these things though I'd probably wear out that feature in a day or so....
Bruce
Bruce Herrmann
