It is currently Tue Dec 03, 2024 3:41 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 20, 2007 11:32 pm
Bob, I really like your router jig/drum sander method in that other thread. I guess it's jig making time again...
PostPosted: Tue Aug 21, 2007 12:28 am
[QUOTE=Hesh1956]
Not to worry about my thunder - the only thunder that I have tends to make my dog leave the room.....
Poor Sony, What you put him thru Hesh
Thanks again for another great Tute.and taking the time for all the great pics and comments! I'm sure I speak for everyone when I say Thanks Much Hesh.
PostPosted: Tue Aug 21, 2007 1:18 am
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
Hesh wrote:
"I forgot to erase the pencil marks prior to gluing so even though I have a gapless fit the pencil marks show......
Any way I turned out great. I dish sanded it to true the bottom and that took a whole of three minutes and then I flat sanded the top for the reinforcement that will be added later. Take a peek and sorry about the pencil mark.... " (emphasis mine)
Yes, Hesh we already know that!
This is a great thread!  Keep em coming!  Please!
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Tue Aug 21, 2007 1:27 am
Online
City: Lawrence
Zip/Postal Code: 66047
Very nice Hesh, Thinning the brace to fit, Why didn't I think of that. And I thought I was the only guy using weight for clamping, I use 1lb chunks of lead.
PostPosted: Tue Aug 21, 2007 1:54 am
[QUOTE=Hesh1956]Thank Waddy that one with the snakewood handle has my name on it [/QUOTE]
Hesh, the way those knives are designed, they are made to work in both directions.  Bevel on one side, angled to a point in the center, lets you flip it around and mark in the other direction keeping the flat side to the inside of the mark.  The Hock knives are a good example of left and right hand marking blades.
PostPosted: Tue Aug 21, 2007 2:14 am
Onya Hesh,
Can always rely on you to make the sort of post which maintain the OLF's standing on the internet as a friendly useful resource and a most worth while place for guitar builders to hang out
Thanks mate
PostPosted: Tue Aug 21, 2007 5:50 am
Hesh! Pencild marks!!!! tisk tisk.... I'm appalled at the lowering of the standards from the Heshtone stables!
Great work! Keep'em comming!
PostPosted: Tue Aug 21, 2007 6:39 am
Last Name: Abercrombie
[QUOTE=Alain Desforges] Hesh! Pencild marks!!!! tisk tisk.... I'm appalled at the lowering of the standards from the Heshtone stables!
And, there was a wood shaving and some sawdust showing in some of the pics as well.
Sad to see Hesh turning into such a slob.....
PostPosted: Tue Aug 21, 2007 7:58 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
I cheat and draw the radius and most of the braces on band saw, on or leaving just a trace of the pencil lines. I then sand(using radius dishes)or use router table on bottom radius. I am going to make jigs for router table for the scallops and then make up a bunch of left and right side of X's and other bracing for tops and backs. Probably enough for 8 guitars anyway. Then when using them just need to clean up the sanding and tool marks. I made a thing like one of the others for table saw X lap joint and use a daddo blade for that. Use vacuum press and do all of the braces for top or back all together. I must correct thing here. I am going to do this as have in past, but right now have to build my shop again with all of the moves.
PostPosted: Tue Aug 21, 2007 9:23 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Hesh, you have the cleanest shop I have ever seen! I'll post a picture of my shed some day...it will make your shop look even nicer!
http://www.PeakeGuitars.com
