It is currently Sat Jul 19, 2025 11:44 am
PostPosted: Sat Jul 21, 2007 12:53 pm
hi to all!
it been a while since i've logged in this forum. i do peek in everyday for
i've been busy with my first guitar and this forum has helped me
immensely.
my question is: what do i do when the rosette i've purchased is not a
perfect circle? it's off by a hair, but it would not fit snugly in the channel.
aside from making a silly coaster out of it and getting a new one...
thanks
PostPosted: Sat Jul 21, 2007 1:45 pm
If you use Titebond or Hide glue, the water will likely swell it to fit, perfectly.
Let us know how it works out if you choose to use it.
Photos, remember we all like those photos....
PostPosted: Sat Jul 21, 2007 2:24 pm
what kind of rosette is it?
PostPosted: Sat Jul 21, 2007 2:44 pm
Is it a complete solid circle and how far off is it?
PostPosted: Sat Jul 21, 2007 3:25 pm
its just one of those pre-made rosettes for a classical guitar.
its not a complete circle, and its off by about half a millemeter, its bigger
(or wider) than the channel.
thanks
PostPosted: Sat Jul 21, 2007 3:51 pm
If it's wider all the way around just cut the channel a little wider.
You can also judiciously scrape the rosette to fit.
PostPosted: Sat Jul 21, 2007 4:44 pm
Is there a reason you can't expand the channel to fit the rosette? And did you say that it wasn't a perfect circle... is it asymmetrical?
Christian
PostPosted: Sun Jul 22, 2007 3:46 am
First name: Josh
Last Name: French
City: Houston
Actually, all you really need to do it make sure the channel is wide enough to fit the rosette and glue it in place. The rosette will fit in the channel fine even if its not a perfect circle until then.
Instagram: @jfrenchluthier
PostPosted: Sun Jul 22, 2007 4:13 am
That's why I asked if it was a complete circle. If it is open on the fb end you should be able to manipulate it enough to get it into the routed channel.
PostPosted: Sun Jul 22, 2007 10:43 am
I'm a first time builder and here's what I did:
I routed a "test" channel into a piece of hardboard until I got a good fit.
Then I used the hardboard channel to set the circle cutter for routing into the guitar top.
Ray
PostPosted: Sun Jul 22, 2007 1:51 pm
its asymmetrical by a few degrees bending outward.
i did as jim suggested, removing material around the channel, and then
gently (with some silent gnarling) pushed it in. fits good.
thanks for your help guys!
PostPosted: Sun Jul 22, 2007 3:03 pm
GLad you got it figured out!
Nice looking rosette by the way!
PostPosted: Sun Jul 22, 2007 3:16 pm
Glad that worked for you.
PostPosted: Mon Jul 23, 2007 7:46 am
hahaha!  i apologize for not posting any pics of it.  my camera is in my other office, the classroom.
nonetheless i will get my camera as soon as the summer school ends and i will post pics of my first build (mistakes and all) for the forum.
i am having a blast with guitar building, but i suspect that it is addicting.  how far gone are you guys?
again thanks for your patience and help
PostPosted: Mon Jul 23, 2007 9:39 am
Nice looking rosette.
