Removing long thru saddle on modern 'vintage' Martin
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=55217
Author:  jfmckenna [ Sat Aug 27, 2022 12:29 pm ]
Post subject:  Removing long thru saddle on modern 'vintage' Martin
It's my understanding that these are glued in with CA?
Using my standard technique of a slit in cardboard protected by AL foil over the bridge exposing the saddle with a heat lamp simply will not work like it easily does on true vintage hide glue ones. And I mean I got this sucker HOT and just will not budge.
What do y'all do? Just rout it out and start over?
Author:  Barry Daniels [ Sat Aug 27, 2022 1:06 pm ]
Post subject:  Re: Removing long thru saddle on modern 'vintage' Martin
I have seen one technique where you saw down the middle of the saddle with a razor saw until you near the bottom. Then squeeze it from the sides with pliers to break the two halves free.
I think I saw this on Frank Ford's site.
Author:  Cal Maier [ Sat Aug 27, 2022 5:57 pm ]
+1 for Barry’s suggestion. It has worked for me with hard to remove or broken glued in saddles. I have used a circular saw in a dremel tool it worked fine, just take your time.
Author:  jfmckenna [ Mon Aug 29, 2022 6:18 pm ]
Saw through worked like a charm, thanks.
