Vibrating truss rod
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=53680
Author:  Bosco Birdswood [ Fri Nov 13, 2020 3:58 am ]
Post subject:  Vibrating truss rod
Hi team,
A friend has a Les Paul with a rattling / vibrating truss rod. I’ve done some quick research and have heard a few mentions of Chair-Loc / Swell Lock which is a solution that makes wood permanently swell. It’s designed to tighten loose fitting wooden chair leg joints, but apparently works well when injected into a truss rod cavity as it makes the wood swell and clamp down on the truss rod a bit.
Just wondered if anyone here had experience of this? I don’t really want to go removing inlays and drilling holes in the board if I don’t have to. Tightening the rod does not resolve the issue unfortunately.
Thanks in advance.
Author:  jfmckenna [ Fri Nov 13, 2020 8:11 am ]
Post subject:  Re: Vibrating truss rod
Yup it works like a charm. But first... Did you try tweaking the rod to see if that helps? Sometimes you just have to activate the rod. Put it under just a bit of tension to get the rattle out. That is of course assuming it's totally loose.
