how to shine/polish a guitar table after sanding with 1000gr http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=53575 |
Author: | the_doc735 [ Thu Oct 08, 2020 4:42 pm ] |
Post subject: | how to shine/polish a guitar table after sanding with 1000gr |
how to shine/polish a guitar table after sanding with 1000grit paper? I just dropped some black super glue on the table of my PRS SE, rubbing alcohol didn't even touch it! Neither did 2500 grit paper so I used 1000 grit paper which removed the glue but has left the surface dull/rough/matt, and the shine has gone! Is there a way to restore the shine without clear coating the whole thing? I tried some D'Addario PW-PL-02S Liquid Carnauba with a microfibre cloth without much success, but I only did it briefly! many thanks! |
Author: | Glen H [ Thu Oct 08, 2020 5:07 pm ] |
Post subject: | Re: how to shine/polish a guitar table after sanding with 10 |
Go back to your 2500 grit and work the area. You may need to use some interim grits. Then work it with rubbing compound then polishing compound |
Author: | Freeman [ Thu Oct 08, 2020 6:12 pm ] |
What Glen says. Go back up the grits from 1000 - 1200, 1500, 2000 and your 2500 (wet). Then polish with a good compound (I use Meguiers #2 and 3) without wax or silicon. |
Author: | the_doc735 [ Sun Oct 11, 2020 11:11 am ] |
I'm getting these: https://www.ebay.co.uk/itm/K2-GOLD-LUSTER-Q5-FINE-CUT-Compound-Polishing-Car-Paint-Acrylic-NO-SWIRLS-Gloss/162466877160?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 https://www.premiumhobbies.co.uk/polish-wax/foam-polishing-pad-kit |
Author: | Barry Daniels [ Sun Oct 11, 2020 5:36 pm ] |
That is a very fine compound and might not be enough to get out 1000 grit, or finer, scratches. You might want to start with a more aggressive cutting compound. |
Author: | the_doc735 [ Tue Oct 13, 2020 8:55 am ] |
Barry Daniels wrote: That is a very fine compound and might not be enough to get out 1000 grit, or finer, scratches. You might want to start with a more aggressive cutting compound. What would you suggest please? thanks! |
Author: | Barry Daniels [ Tue Oct 13, 2020 9:12 am ] |
There are a lot of compounds that would work, but this is my preference: https://www.amazon.co.uk/Meguiars-Mirror-Glaze-Ultra-Cut-Compound/dp/B01LRHDOUC/ref=sr_1_1?dchild=1&keywords=meguiars+105&qid=1602598287&quartzVehicle=106-1339&replacementKeywords=meguiars&sr=8-1 |
Author: | the_doc735 [ Thu Oct 22, 2020 5:17 am ] |
I used 1500, 2000, 2500 papers and these: https://www.ebay.co.uk/itm/K2-GOLD-LUST ... 2749.l2649 https://www.premiumhobbies.co.uk/polish ... ng-pad-kit It worked very well! Many thanks for all your guidance, much appreciated to everybody here. |
