Changing bracing pattern, a question
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=52748
Author:  V Silly [ Fri Dec 20, 2019 4:00 pm ]
Post subject:  Changing bracing pattern, a question
Hello folks, I have an inexpensive Kay ladder braced bolt on neck acoustic guitar that I wanted to use as the basis for an experiment with a different brace pattern. I am uncertain what the best approach is and was hoping for some insight. I thought I was going to remove and reuse the existing top, but so far I have not figured out how to get it off without destroying it. Is there another better approach? Since the neck is a bolt on, removing the top would be easier than on a standard guitar where the fretboard is glued to the top, but maybe approaching it from the backside would be easier? Thank you :-)
Author:  CarlD [ Fri Dec 20, 2019 5:04 pm ]
Post subject:  Re: Changing bracing pattern, a question
Take the back off, then you have access to plane/chisel the old braces off.
Author:  flemsmith [ Fri Dec 20, 2019 8:31 pm ]
Curious, Is removing and replacing the back a process that with new binding can look pretty much original?
Author:  CarlD [ Fri Dec 20, 2019 9:02 pm ]
I've been contemplating doing this to an old Kay. I've already reset the neck. It was a dovetail with a glued fretboard extension. The back had some loose edges so I pulled it and was able to remove the binding intact, so reinstalled it when I glued the back on. The finish was old, checked and flaky so I just went with its character and let it be.
Check out Dan's posts about rebuilding an old Kay, viewtopic.php?f=10137&t=52549.
Also this rebuild series, https://www.youtube.com/watch?v=3grzGLgSlnc&t=1749s.
