Surface thermometer http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=52504 |
Author: | Smylight [ Fri Oct 04, 2019 8:21 am ] |
Post subject: | Surface thermometer |
Hello friends, For those that do use them, what do you guys and gals use as surface thermometers? StewMac has one, is that the only game in town? Anyone using one of those cheap infrared gun types? Pierre Guitares Torvisse |
Author: | bobgramann [ Fri Oct 04, 2019 2:06 pm ] |
Post subject: | Re: Surface thermometer |
I have used both the bimetal one like stewmac’s and the electronic one. The bimetal curl thermometer seems to report close to the correct temperature (at least of the air near the surface) but I have never calibrated it against something known like boiling water. The electronic one with the laser pointer reflects off of anything metal so it won’t give accurate readings of my bending iron. While I was curious to see what temperatures I was bending at, I still go with how the bend feels to know if the temperature is sufficient. I rarely use either thermometer in my shop although I have them. |
Author: | Smylight [ Sat Oct 05, 2019 10:49 am ] |
I'd primarily use it to unglue fingerboard and lifting bridges, and I'm typically using a clothes iron or light bulbs, so metal temp is not a strong concern for me. Pierre Guitares Torvisse |
Author: | Smylight [ Sun Oct 06, 2019 8:04 am ] |
Anyone else has experience with surface thermometers for my intended purpose? Pierre Guitares Torvisse |
Author: | SteveSmith [ Sun Oct 06, 2019 1:51 pm ] |
IR thermometers will read the surface temperature of just about anything. We used them at work for years to check for hot spots in our machines; I use one in the shop primarily when removing bridges and fretboards with a heatlamp. |
Author: | Smylight [ Sun Oct 06, 2019 4:12 pm ] |
SteveSmith wrote: IR thermometers will read the surface temperature of just about anything. We used them at work for years to check for hot spots in our machines; I use one in the shop primarily when removing bridges and fretboards with a heatlamp. Exactly what I was looking for. Thanks Steve. So those cheap IR units will do the job, I suppose? Pierre Guitares Torvisse |
Author: | SteveSmith [ Sun Oct 06, 2019 5:46 pm ] |
They're not dependable for high accuracy but they'll give you a good general idea of the temp in an area. |
Author: | Smylight [ Sun Oct 06, 2019 9:02 pm ] |
Great, thanks. Pierre Guitares Torvisse |
Author: | Dave Rickard [ Mon Oct 07, 2019 10:55 am ] |
Steve, Do you think they would be +/- 10 degrees ? THANKS SteveSmith wrote: They're not dependable for high accuracy but they'll give you a good general idea of the temp in an area.
Author: | Ruby50 [ Mon Oct 07, 2019 12:45 pm ] |
It's been 7 years since I retired, but my company performed infrared scans of various things. We used hand held scanners for many things, and the small pistol grip infrared thermometers for others. The small ones you can by locally, like this one https://www.lowes.com/pd/Digital-Temperature-Meter/3028851 were within about 1.5 degrees of accurate. You have to understand a little about infrared, but generally it depends on the surface you are scanning. Metal and glass don't register accurately, but things like wood, plastic, drywall, paint are pretty close. Just don't get the laser aiming light anywhere near metal and you should be OK And things may have changed in the last 7 years. Ed |
Author: | SteveSmith [ Mon Oct 07, 2019 1:16 pm ] |
Dave Rickard wrote: Steve, Do you think they would be +/- 10 degrees ? THANKS Like Ed said, within a few degrees. The cheap one I use in the shop I figure is within 5 degrees. Main thing to keep in mind is what you are measuring is the temperature at the surface.
SteveSmith wrote: They're not dependable for high accuracy but they'll give you a good general idea of the temp in an area. |
