It is currently Fri Jul 18, 2025 10:16 pm
PostPosted: Sun May 06, 2018 11:57 am
First name: Freeman
Last Name: Keller
A friend of a friend called me, "got an old Gibson with a broken neck, was told that if anyone could fix it you could". Ah, well, OK. Thinking it was just a normal broken Gibbie head I said "sure, bring it over"
Well, it turned out to be a 1978 (he says) Custom that was badly broken thru the heel, the neck was popped out of the cavity. Binding was broken off both sides. That would have been pretty straight forward but the owner decided to fix it, my guess is that he used water activated polyurethane, which happens to expand as it cures. I also doubt that he clamped the neck back into the pocket. It looked like this
The good thing about gorilla glue is that it wasn't ever going to come apart. The bad thing about gorilla glue is that it wasn't going to come apart.
In addition, the neck geometry was now completely fubar
And someone had removed the wiring with a pair of diagonal cutters
To add insult to injury, the original Nashville ToM bridge had been lost so they jury rigged a cheap made in Korea ABR-1 style bridge to work by wrapping paper around the M4 threaded studs to make them fit in the M5 bushings
PostPosted: Sun May 06, 2018 12:08 pm
First name: Freeman
Last Name: Keller
The geometry was bad, but close enough that I figured it was worth a try. Some bondo (yes, Virginia, bondo) in the heel
And some binding spliced into the old
A few coats of black lacquer with some vintage amber on the binding
The electronics were toast - the switch was intermitent, the pots were scratchy, when I tried to pull the knobs the shaft came out of one so I rewired with all new components
I just happened to have the correct Nashville stud but I didn't have a vintage gold bridge so I put the POS one back in while we look for an old one
Did a bunch of work on the truss rod and frets (they are the original kind with the plastic nibs) and got the action pretty reasonable. Took it inside, plugged it in and played it for the first time in a lot of years
PostPosted: Sun May 06, 2018 1:58 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Nicely done. The guitar restoration looks good.
PostPosted: Sun May 06, 2018 2:33 pm
Of course, with all the damage - there was plenty of potential. Well done, sir!!!!
PostPosted: Sun May 06, 2018 5:09 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Great job Freeman - almost as good as new
Ed
PostPosted: Sun May 06, 2018 5:42 pm
First name: D
Last Name: S
Are the frets original fretless-wonder style?
If so, thanks for not replscing them with jumbo’s.
Very well done!
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun May 06, 2018 8:41 pm
First name: Freeman
Last Name: Keller
Very well done!
Yes, still have the nibs. I massaged them a little but kept them original.
These users thanked the author Freeman for the post: dzsmith (Mon May 07, 2018 12:06 pm)
PostPosted: Mon May 07, 2018 5:39 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Nice! I love a good save!
Brian
