It is currently Fri Jul 11, 2025 7:48 pm
PostPosted: Sat Feb 10, 2018 9:43 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
So When I fret an E note on the A string (7th fret) and play the open G string simultaneously I get this crazy zinging sound that disappears if I touch behind the 7th fret on the A string at the same time, removing the vibration behind the fretted note. Obviously the G note is causing some kind of sympathetic vibration with the A string behind my fretted note, but I've never seen this before. What could cause that, a too low fret behind, kind of like the reverse of when you press down on a low fret?
