Gibson J35 Update Sound Link http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=42634 |
Author: | WudWerkr [ Tue Feb 04, 2014 2:15 pm ] |
Post subject: | Gibson J35 Update Sound Link |
Have a young Man who has brought me a Gibson J35 Acoustic Electric ... The Neck Is Twisted , and he says getting worse . I called Gibson , they wont sell me a Replacement neck . Any Suggestions ? |
Author: | B. Howard [ Wed Feb 05, 2014 8:24 am ] |
Post subject: | Re: Gibson J35 |
Make one. I see Gibson acoustics every once in a while that have had replacement necks made and installed and I am known to make the odd replacement neck when the situation arises. |
Author: | WudWerkr [ Wed Feb 05, 2014 9:31 am ] |
B. Howard wrote: Make one. I see Gibson acoustics every once in a while that have had replacement necks made and installed and I am known to make the odd replacement neck when the situation arises. Whats it going to do to the Value of the Guitar not being original ? Making the Neck isn't an issue , its Keeping the Value I'm questioning |
Author: | B. Howard [ Thu Feb 06, 2014 8:41 am ] |
Value is already gone...... with a badly warped neck it is only a wall hanger, a piece of art. Make a faithful enough reproduction and most will never know. You can salvage the face plate from the headstock and reuse it. |
Author: | WudWerkr [ Thu Feb 06, 2014 3:14 pm ] |
Update , Looking down the neck from head stock , it does appear to have a slight twist . HOWEVER , when I did some checking with Parallel's its not twisted . The Bridge on the J35 is an angled bridge and the Saddle has been ground down on an angle as well " not factory " the whole thing creates an optical illusion . ![]() Because someone messed with the bridge the action above 12th fret at 1st string is .040 and at 6th is . 058 and he wonders why it buzzes ... Also , whoever messed with it before loosened the truss rod nut to the point it was about to fall off ..... ![]() ![]() Btw , where he had it worked on before was a "Reputable " Guitar store ... Sad |
Author: | B. Howard [ Fri Feb 07, 2014 8:37 am ] |
Glad it worked out well. |
Author: | Beth Mayer [ Fri Feb 07, 2014 12:54 pm ] |
Way to diagnose, Dr Wud! Guy's lucky he found you. |
Author: | Tony_in_NYC [ Fri Feb 07, 2014 1:43 pm ] |
I think you should figure out how to warp the neck so you can practice fixing it. Or don't. You know...whatever. |
Author: | WudWerkr [ Fri Feb 07, 2014 4:04 pm ] |
Tony_in_NYC wrote: I think you should figure out how to warp the neck so you can practice fixing it. Or don't. You know...whatever. I LIKE the way you think !! ![]() ![]() Be honest with you when I realized what situation was I felt a Little embarrassed that I didn't catch it faster . ![]() |
Author: | WudWerkr [ Mon Feb 10, 2014 9:09 am ] |
http://www.facebook.com/photo.php?v=422688511194515&set=vb.100003601087065&type=2&theater Bridge and saddle repaired , Truss rod adjusted , string height set and . Very satisfied customer ![]() |
