bridge repair http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10137&t=41208 |
Author: | Paul Meier [ Fri Aug 23, 2013 1:08 pm ] |
Post subject: | bridge repair |
First of many likely ridiculous questions, thanks in advance for your patience. When using heat to release a bridge that needs to be reglued should I be concerned about the bridge plate and bracing also loosening from the heat? Maybe clamp those up as the top cools once the bridge is off? |
Author: | Chris Pile [ Fri Aug 23, 2013 2:55 pm ] |
Post subject: | Re: bridge repair |
Dang! As many bridge removals as I've done, and I never gave a thought to the plate underneath. GOOD QUESTION! |
Author: | WudWerkr [ Fri Aug 23, 2013 8:59 pm ] |
![]() I hope more people chime in on this . |
Author: | Stevelkneivel [ Mon Aug 26, 2013 7:12 am ] |
Wood is one of the best insulators out there. I often feel the plate, and when it's warm, you know the bridge will pop off. You can do it cold too. Do you know that trick? |
Author: | WudWerkr [ Mon Aug 26, 2013 9:26 am ] |
Stevelkneivel wrote: Wood is one of the best insulators out there. I often feel the plate, and when it's warm, you know the bridge will pop off. You can do it cold too. Do you know that trick? Enlighten us please ! ![]() |
Author: | Rodger Knox [ Mon Aug 26, 2013 11:03 am ] |
No, NOT the pop it off with a hammer trick! Well, I guess it works when it works... ![]() edit: I thought Steve would be back with his technique, but here's the story. Glue is not very strong in shear, so putting a block in front of the bridge and smacking it with a hammer will cause the glue joint to fail. I've never done this, and wouldn't recommend it, but others have had sucess with this technique. |
Author: | B. Howard [ Tue Aug 27, 2013 4:38 am ] |
I have always been conscious of this, I also worry about loosening the neck block from the top when heating and lifting the fret board extension. But I am happy to say I have not seen any issues...but yes to me it is a concern. I use only as much heat as needed and work as quickly as I can in these instances. |
Author: | Stevelkneivel [ Wed Oct 02, 2013 8:50 am ] |
No you don't shear it. You modify the chisel to get it to sit flatter to the top and you gently tap around the perimeter of the bridge a few times and eventually the sound of the tap changes dramatically....ok it's a shear, but a gradual one. Use a razor blade to cut the fibres holding on underneath. Clear as mud? It does work quite well. And it's neat. It's how Martin did it/ does it. At least they did back in day when I was there. It's really easy as well. |
Author: | Rodger Knox [ Wed Oct 02, 2013 11:47 am ] |
Stevelkneivel wrote: No you don't shear it. You modify the chisel to get it to sit flatter to the top and you gently tap around the perimeter of the bridge a few times and eventually the sound of the tap changes dramatically....ok it's a shear, but a gradual one. Use a razor blade to cut the fibres holding on underneath. Clear as mud? It does work quite well. And it's neat. It's how Martin did it/ does it. At least they did back in day when I was there. It's really easy as well. That make perfect sense, and that is a method I will try! |
