It is currently Tue Jul 08, 2025 10:27 pm
 Post subject: Fret wood filling
PostPosted: Tue Jul 30, 2013 11:51 pm
First name: Shad
Last Name: Hall
Country: united states
hi,
thanks for accepting me to the forums! my name is shad and i'm rebuilding/restoring a couple of guitars, one of which, i need your help.
i am in the process of defretting a classical guitar and you can see the documented progress on my blog for the project ( http://samuraifretless.blogspot.com ). [hopefully, it's okay to post (topic-related) offsite links. if not, let me know, please.] i have been using dap's plastic wood filler to fill in the fret slots, but the wood paste didn't behave like i wished and i had to apply a second application today, but when i pulled off the masked area, it in turn pulled the overflow wood fill and thus pulled out some of the wood filler. sigh ...
what can/should i do to get the surface flush? the fingerboard is rosewood, so i do not want to seal it.
in research, i initially considered 1mm veneer and even balsa wood for slot-fill, but that's not going to work, b/c i used a fine triangular file and ran it through the fret slots to create a very minimal bevel. this helped beautify and remove some of the scarred fingerboard from the impression left by the fret.
i'm really at a loss of what to do. i'm completely comfortable working on acoustic guitars and though i have some luthier experience, i've never done a project like this one. i also have a wood shop, so i'm not intimidated by tools. however, i don't want to mortgage the house to complete this project. (LoL)
thanks in advance!
shad
p.s. i'm off to update my profile page.
 Post subject: Re: Fret wood filling
PostPosted: Wed Jul 31, 2013 2:22 am
Welcome to the forum Shad.
I would post this in the main forum. You will probably get more replies.
FWIW, I would plane off a couple of mm and glue on a veneer to give the proper string height above the soundboard at the saddle.
PostPosted: Wed Jul 31, 2013 6:53 am
If I understand your problem, I would either use heat (hair dryer or heat gun, but go easy) or solvent (probable naptha) to release the tape. Alternatively, do you need to mask it? Could you fill the slots and just clean it up by resanding the fretboard flat?
Mike Lindstrom
PostPosted: Wed Jul 31, 2013 7:03 am
Colin's idea will work best if you want a smooth surface on top of the fretboard. However, if you want to use a filler of some kind in the slots there are things that should work better than DAP.
1. Use a fine-toothed saw to even out the widths of all the fret slots, maybe something in the 0.028 to 0.032" range or even larger if you like. Kind of depends on what you have available. Glue in slices of the wood of your choice. You could use something that matches or pick a contrasting wood.
2. You can pack the fret slots with wood dust and then wick on some thin CA glue. I usually use 320 sandpaper to make my sanding dust. Note that the wood dust will turn a lot darker with the CA so test some on scrap first to get the look you want.
3. You can also make a slurry of epoxy and wood dust. Pretty much the same as 2, above.
PostPosted: Wed Jul 31, 2013 1:12 pm
First name: Shad
Last Name: Hall
thanks everyone. i've been reading and re-reading and contemplating the approaches mentioned. what i'm leaning towards right now, is getting that glue resin off the fingerboard and then sanding it again and use the build up wood dust with the CA glue and fill in the blank spots in the fret slots. it will kind of give it a varied 2-tone effect that may look pretty cool ... well, it will either look good or really crappy. lol thoughts?
now, a question about naptha? does it have to be naptha? can i use acetone/nail polish remover? paint thinner? (obviously, i don't know the pro's/con's of particular solvents.)
PostPosted: Wed Jul 31, 2013 10:38 pm
You're in CA? I think I've read you can't get naptha there. It's easy enough to check. Put some tape on a scrap and see what solvent cleans it up. I'd be nervous about acetone around a finish, but that might be baseless. A little bit of heat works wonders and is less toxic.
Mike Lindstrom
PostPosted: Fri Aug 02, 2013 3:01 pm
First name: Shad
Last Name: Hall
california is really strict and you're right, mike, i cannot get it here. the other day, when i used heat and friction from just rubbing off the glue residue, it did the trick, but afterwords there was a "grease spot" (for lack of a better word) that remained on the fingerboard. perhaps, my hands were dirty from all of the sanding and the grime and hand oils mixed with the glue. my next option is putting mineral spirits on a rag, letting it evaporate a bit and then wipe off the fingerboard with a bit of elbow grease. what do you think? well, i know it will work, but how will the unsealed rosewood respond to it? will it haze/dull?
i found the following quote from some google link.
Quote:
Paint thinner and mineral spirits are usually just different terms for the same thing. Naphtha is a very close relative of mineral spirits, and can also be described by some as paint thinner. Both are petroleum distillates with slightly different pentane, heptane, octane, etc, levels. Naphtha has a lower flash point, and evaporates a bit more quickly. Neither will react with most cured finishes, nor will they swell wood, and are perfectly safe to use for cleaning guitars (with proper ventilation and fire safety precautions of course). White gas used in camp stoves is another close relative, and kerosene isn't that distant either.
thoughts?
PostPosted: Fri Aug 02, 2013 3:05 pm
First name: Shad
Last Name: Hall
p.s. why can't i just use the mineral spirits and even if the fingerboard dulls a bit, could i just VeRy lightly sand the fingerboard to take it down just enough to sand off the dull finish? that sounds logical to me.
thoughts?
PostPosted: Tue Aug 13, 2013 4:30 pm
First name: Shad
Last Name: Hall
hi again,
[to the moderator: if you think this thread will gain more attention in the main forum room, please feel free to move it over there.]
okay, in regards to my previous comment on this thread ...
thoughts?
... and this picture of a guitar top that someone stuck a stick on the top-wood, what would your suggestion(s) be to remove the sticker?
thanks
PostPosted: Wed Aug 14, 2013 2:07 am
First name: nick
Last Name: dingle
That's going to depend a lot on the type of finish, and that, in turn, is going to depend on what kind of guitar it is.
If it's a poly finiah(ie:Jap, 1970-80's) paint stripper won't touch it. If it's a french polish, be very careful, etc...
Got a pic of the label? Would help....
PostPosted: Wed Aug 14, 2013 12:46 pm
First name: Shad
Last Name: Hall
okay, according to the documented information (spreadsheet) i have from a conn guitar aficionado on the web, the finish is "Bright Polyester (Polyurethane)".
there is no label inside the sound hole, only a stamp that reads "made in japan".
make/model: C-11 Conn Classical guitar ("Made in Japan")
year: 1974~78
top: spruce (guesstimating it's sitka)
back/sides: mahogany
fingerboard: rosewood
PostPosted: Tue Aug 20, 2013 5:12 pm
First name: Shad
Last Name: Hall
as a week has passed, i'm just bumping up this thread, b/c i'm still [patiently] waiting for an answer. :)
PostPosted: Tue Aug 20, 2013 5:14 pm
Try some lemon oil.
PostPosted: Tue Aug 20, 2013 5:16 pm
First name: Shad
Last Name: Hall
Chris Pile wrote:
Try some lemon oil.
okay, thanks! :)
