It is currently Fri Aug 22, 2025 8:57 am
PostPosted: Thu Aug 14, 2014 6:42 pm
First name: Bryan
Last Name: Hibler
City: Marble Falls
Zip/Postal Code: 78654
Country: United states of America
I was getting suspicious that the hide glue didn't cure correctly or was too weak on my bridge that I had to reglue. 192 gram strength.
It's been a month and this week it started opening back up.
What should I do?
Higher strength glue, try the old again, Fish glue, or Titebond?
PostPosted: Fri Aug 15, 2014 7:09 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Problem may not be the glue itself. If the fit of the joint isn't tight it will fail, if there was residue from another adhesive like titebond it will fail. If the HHG gelled before it was clamped it will also fail. 192 gram glue is plenty to hold the bridge on.
Brian
These users thanked the author B. Howard for the post: gxs (Fri Aug 22, 2014 12:11 pm)
PostPosted: Fri Aug 15, 2014 5:38 pm
First name: Bryan
Last Name: Hibler
City: Marble Falls
I had pullout originally, but wasn't that bad. I'm thinking that I messed up anyways, because I didn't heat the 2 surfaces before apply the HHG.
