It is currently Thu Nov 21, 2024 4:38 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 22, 2012 3:08 pm
State: Tennessee
Very nice. Especially using salvaged wood. I am using Local Tennessee wood for my build, most I cut off my place.
So you compensate the nut then the saddle?
Looking forward to hearing this guitar.
PostPosted: Thu Feb 23, 2012 12:41 am
First name: Trevor
Last Name: Gore
City: Sydney
Thanks, everyone, for the kind words.
Wud, the joint is a double tenon, pic on my website here:
http://www.goreguitars.com.au/main/page_innovation_summary_neck_joint.html
Clinchriver, good luck with your build! Regarding the intonation, there's a bit more about it here:
http://www.goreguitars.com.au/main/page_innovation_summary_nut__saddle_compensation.html
I establish the nut compensation for the strings/set-up etc. I want using a computer program that I wrote, which also delivers an active string length. I install the intonated nut, string the guitar, let it settle, then measure off the active string length and compensate the saddle. Somewhat mathematically intense, but works really well. I go through a few less mathematically intense methods in the book which give pretty good answers, rather better than the standard 12th fret method!
Still working on getting a recording done...
PostPosted: Thu Feb 23, 2012 8:42 am
First name: Big
Last Name: Jim
Thanks for the Link . I like that neck joint . You explination on the site makes perfect sense to me . I may try a version of that as well one day . Great build thread here !
PostPosted: Sun Feb 26, 2012 9:57 am
First name: Tom
Last Name: Walters
City: Kaministiquia
Zip/Postal Code: P0T1X0
Trevor,
Let me add my congratulations on your recycled guitar. I was fascinated by the bracing ...particularly the top. Did you laminate the top curved braces and bend them?
How did you come up with this bracing pattern and how does it sound?
Thanks again for posting this build.
Tom
:D :D :D
PostPosted: Tue Feb 28, 2012 4:22 am
First name: Trevor
Last Name: Gore
City: Sydney
Hi Tom. The braces are laminated and each laminate is heat bent first.
BaldEagle55 wrote:
How did you come up with this bracing pattern...
It's just a way of bracing with more efficient use of material; basically putting the material where the stiffness is required then dissipating the load effectively over the whole soundboard. It was inspired by seeing the way some sails were reinforced (but some people have struggled to see the connection!)
BaldEagle55 wrote:
...and how does it sound?
Well, there's quite a few people tried out falcate bracing now, and many have said they've built their best guitars using this bracing system. I designed this style of bracing particularly for my "steel string concert classical" guitars, which are very responsive finger-picking instruments, and I think this type of bracing style is best suited to that kind of guitar. I can get very even response at high volume over all the strings with this bracing. I would, however, advise that there's a lot more going on in a good guitar than just the bracing system.
These users thanked the author Trevor Gore for the post: Al Pepling (Wed Feb 19, 2014 7:00 pm)
PostPosted: Thu Apr 26, 2012 4:26 am
First name: Trevor
Last Name: Gore
City: Sydney
I've been promising to put up a sound file for The Shed guitar for a while now. I've been messing around with some new software (Pro Tools) and an MBox and I've got a first take, but it's little more than a sound check. It's only me playing (so don't get excited!) and I've now broken a fingernail (violin) so, being a finger-picker, it'll be a while before I get a second take up and running.
Anyway, I thought I'd put a peg in the ground just in case I don't get round to "Take 2". The left channel is recorded using a condenser mic and the right channel is the K&Ks direct into the MBox. After MP3-ing, both channels sound pretty similar, but they are different!. If you listen carefully (needs headphones) you can hear the rain on the Shed's tin roof on the left channel with the K&Ks picking up me scruffling around on the right channel.
Different mic placement and some impedance matching for the K&Ks will likely produce a more realistic result, so that's what "Take 2" will be about if I get to it.
Oh well, that was the plan! Just got a message "The extension mp3 is not allowed". Where to from here? Perhaps here:
http://www.anzlf.com/viewtopic.php?f=25&t=3842&start=25#p50295
...where there's a will...
PostPosted: Thu Apr 26, 2012 10:09 am
First name: Jason
Last Name: McGowan
City: Corinth
Zip/Postal Code: 76210
Wish I could "sound check" like that Trevor, sounds amazing. What is the song that you're playing?
Jason McGowan
M&S Guitars
_____________________________
United States of America, looks like another silent night
As we're sung to sleep by philosophies that save the trees and kill the children....
Casting Crowns
PostPosted: Thu Apr 26, 2012 7:37 pm
First name: Trevor
Last Name: Gore
City: Sydney
It's the old folk tune, Scarborough Fair, (Parsley, sage, rosemary and thyme...). Simon and Garfunkel did a version which this picking pattern is similar to. It's usually played with a capo at 7, but here there's no capo at all.
PostPosted: Sat Apr 28, 2012 6:09 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Nice playing!
I'm trying to record a sound clip for a recent build,
and it's really hard.
Especially when it's just a bare bones guitar.
