Making Rosie's First Guitar (480mm scale classical) My #3 http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10130&t=42550 |
Page 1 of 3 |
Author: | Nick Royle [ Sat Jan 25, 2014 5:49 pm ] |
Post subject: | Making Rosie's First Guitar (480mm scale classical) My #3 |
Hi everyone, I thought I'd share photos of my current build, a small classical for a good friend's daughter. Here is the mockup... Attachment: rty.jpg Some of you will recognise it from this, http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=41311, thread. This is only the third acoustic guitar I've built (the second on my own as I built my first under the supervision of a tutor) so I'm still a newbie trying to get to grips with things but I thought I should show my work and expose myself to some critical eyes. I did post pics of my last guitar here, http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=41035, but none of the actual build process as I decided from the very beginning not risk losing focus by worrying about taking pics all the time. This time, I've been taking photos as I go along and compiling a photo book for the young owner-to-be! She's enjoying seeing it come together and hopefully some of you guys will too! I've just finished binding the body so there are a good eleven messages worth of pics. I'll upload them all as quick as possible. (The language in the photo book is written for a child so I'll just quicly summarise each pic, if anyone has any questions about how I did something (or why I didn't do something), let me know! All comments welcome! --------------------------------------------- Attachment: image001.jpg Here is most of the wood. Very inexpensive from Madinta but I don't think I could be happier with the grain if I'd have chosen from stacks. Carpathian spruce top with EIR back, sides, faceplate, and fretboard, and maple neck rosette and binding (not in picture). Attachment: image002.jpg The sides Attachment: image005.jpg Working on the thickness sander Attachment: image006.jpg Getting there! Attachment: image007.jpg After sanding to 2.2mm, I cut to size and the first one spent 10 minutes in the bath to get wet Attachment: image008.jpg On the bending iron! (Just for the record, I don't recommend using a heat gun. It only just got the pipe hot enough and it took over 30 minutes to heat up. The propane torch takes less than half that time and gets higher temps.) Oh, and the tin foil obviously isn't enough heat protection to avoid the smell of smoldering plywood! I'll use a tile next time. If I don't make a sidebender.) |
Author: | Nick Royle [ Sat Jan 25, 2014 5:54 pm ] |
Post subject: | Re: Making Rosie's Guitar (480mm scale classical) |
Attachment: image009.jpg Checking against the template Attachment: image010.jpg Nearly there Attachment: image011.jpg One side done Attachment: image012.jpg Both sides done. I made that one ply mold but it was next to useless so, really, I built this guitar free form. Attachment: image014.jpg Splitting braces (not at all staged after I forgot to get someone to take a pic!) Attachment: image015.jpg Braces Attachment: image016.jpg A spruce tree! ![]() |
Author: | Nick Royle [ Sat Jan 25, 2014 5:57 pm ] |
Attachment: image017.jpg Smoothing Attachment: image018.jpg Roughly sized Attachment: image019.jpg Everything so far Attachment: image020.jpg Sides together Attachment: image021.jpg Kerfing going on Attachment: image022.jpg Kerfing on! I used a flat top and a 16 foot radius back. Used a radius dish for the back. Attachment: image023.jpg Marking for end graft |
Author: | Nick Royle [ Sat Jan 25, 2014 6:01 pm ] |
Attachment: image024.jpg Chiseling slot Attachment: image025.jpg Clamping Attachment: image026.jpg Shooting the back Attachment: image027.jpg back together Attachment: image028.jpg Joining top. I used the tape method this time, worked well! (And that Elvis sleeve was for the first record I ever bought!!!!) Attachment: image029.jpg Top joined Attachment: image031.jpg Maple ring for the rosette |
Author: | Nick Royle [ Sat Jan 25, 2014 6:06 pm ] |
Attachment: image033.jpg Took me a few goes to cut! Attachment: image034.jpg Gluing rosette purfling with drawing pins (push pins/map pins) Attachment: image035.jpg And the inside... actually, I broke that rosette in a momnent of furious sanding so I had to make another one. I forgot to tape pics but second time around, I inlaid a maple ring into rosewood and then cut it out again. I only wanted the rosewood line to be 0.5mm, so it was risky cutting that close, but it turned out ok. Attachment: image036.jpg Practiced the inlay first Attachment: image037.jpg Finished! Not tooo bad. I ran out of the maple a few photos back so I used some 0.7mm maple veneer. Just got to be careful not to sand through it!!! Attachment: image038.jpg Thicknessing the top to 1.9ish. Will be 1.8 when final sanded I hope and thinner round the edges. |
Author: | Nick Royle [ Sat Jan 25, 2014 6:11 pm ] |
Attachment: image039.jpg Thicknessing the back. I stopped at 2mm, maybe slightly less, because it was practically flapping in the wind! Attachment: image040.jpg Top and back stickered for 5 days at 47% to prepare for cross grain gluing. Hopefully an adequate precaution. Attachment: image042.jpg Gluing a soundhole patch... I cut the thin top and back panels out with the Dremel in the Stewmac base. Didn't fancy risking it with a coping saw, however small or big. Attachment: image043.jpg Hole cut Attachment: image044.jpg Gluing fan braces Attachment: image045.jpg Carving 'em... Took 'em down to 3mm ish in the end as per a Torres plan. If that's too thin, I don't want to know! Well, I do. But break it to me gently. ![]() |
Author: | Nick Royle [ Sat Jan 25, 2014 6:14 pm ] |
Attachment: image046.jpg Gluing the a-frame Attachment: image047.jpg After carving/before sanding = 85 grams (and oversize, and brace ends still long. Will be a fair bit lighter really.) Attachment: image048.jpg Gluing marriage strip Attachment: image049.jpg Chiseling slots Attachment: image050.jpg Gluing back braces Attachment: image051.jpg Carving Attachment: image052.jpg Gluing top |
Author: | Nick Royle [ Sat Jan 25, 2014 6:17 pm ] |
Attachment: image053.jpg Trimming top back Attachment: image054.jpg Guitar without back! ![]() Attachment: image055.jpg Gluing back Attachment: image056.jpg Guitar with back. you can just see the template with tabs cut to transfer brace lines to the top. Worked well. Attachment: image057.jpg From the front Attachment: image058.jpg Bending binding. (That may be my new pseudonym, Mr Ben Bendingbinding.) I had an epiphany whilst bending these: I hadn't been holding the bend for long enough so I was bending over and over and not getting the bend to stick! Once I started counting to 60 or 90 whilst holding the bend (off the iron), there was hardly any springback at all... Maaaaybe I don't need the side bender now after all. Attachment: image059.jpg Binding jig. ugly isn't it? ![]() |
Author: | Nick Royle [ Sat Jan 25, 2014 6:22 pm ] |
Attachment: image060.jpg Cutting the binding channels. I said to a friend I could've done three in an afternoon with this jig. actually, I could've done 20 ... even if I had to adjust settings for each one! Great jig. With careful testing. (I don't really feel the urge to replace it with a tower rig or swivel arm rig. Maybe I'll try one of them and think it better but I just don't think I will.) Attachment: image061.jpg All cut Attachment: image062.jpg Binding back Attachment: image063.jpg Binding top Attachment: image064.jpg Lots of tape! Thanks to Todd for recommending the strapping tape. Bleedin good! Attachment: P1070048.JPG Scraping flush... Wow, a sharp scraper is just a joy! I sharpened by rubbing the square end on my 320 grit paper on the scary sharp board (and/or the coarse side of a Stanley oil stone) and then burnished with the Veritas variable burnisher (bought it with Christmas money from m'grandma). First time I've been able to repeatably get a good hook. Attachment: P1070049.JPG Scraping top |
Author: | Nick Royle [ Sat Jan 25, 2014 6:24 pm ] |
Attachment: P1070050.jpg Attachment: P1070068.JPG Attachment: P1070070.JPG Attachment: P1070072.JPG Attachment: P1070073.JPG Attachment: P1070075.JPG I'm pretty pleased with that. Only the second time I've done wooden binding. (Binding only looks a bit thicker on one side because I'm yet to scrape around the bit I had to retape.) (The guitar isn't symmetrical but I think I'd get sucked into the underworld if I ever made a symmetrical guitar! To be brutally honest, the reason it isn't symmetrical is mainly down to me not holding the bends for long enough and them not setting properly, so by the time I got to this point, I just said, "that's close enough"... Never again.) |
Author: | Nick Royle [ Sat Jan 25, 2014 6:27 pm ] |
Attachment: image065.jpg Cutting fret slots Attachment: image066.jpg Cutting MOP for inlay Attachment: image067.jpg All cut Attachment: image069.jpg Practicing routing inlay cavities Attachment: image070.jpg Done! Well, that's about it for now. Just working on the neck now. Hope those who enjoy build threads like what they see! I welcome any comments! All the best, Nick Here's a test dying the spruce purple... Attachment: PURPLE-WOOD!!!!!!.jpg
Author: | Dave Livermore [ Sat Jan 25, 2014 9:04 pm ] |
Post subject: | Re: Making Rosie's Guitar (480mm scale classical) My #3 |
That is a fantastic photo journey. Keep the pictures rolling. dl |
Author: | Nick Royle [ Sat Jan 25, 2014 10:10 pm ] |
Post subject: | Re: Making Rosie's First Guitar (480mm scale classical) My # |
Thanks Dave, glad you like them! I'll be posting more within days! |
Author: | Joel Barbeau [ Sun Jan 26, 2014 9:17 am ] |
'Binding jig. ugly isn't it? ![]() A binding jig is only as pretty as the binding job it makes, and yours looks great! Very cool, I like the headstock. |
Author: | emoney [ Sun Jan 26, 2014 9:22 am ] |
That's awesome, Nick! Looking forward to seeing that "subtle" color when you're done. Thanks for sharing. |
Author: | Nick Royle [ Sun Jan 26, 2014 9:00 pm ] |
Quote: A binding jig is only as pretty as the binding job it makes, and yours looks great! Thanks Joel, very kind of you to post and say that! I'm quite proud of it! And I'm glad you like the headstock. At one point I thought I'd never make a nice loooking design for it and the bridge... for this guitar or any other! My creativity was letting me down! But with a very kind and helpful OLF user to bounce ideas off, I eventually got to something I like! Maybe there is hope for me yet! I thought I was doomed to only copying others for a moment! And, Eric, thanks for the compliment! Quote: Looking forward to seeing that "subtle" color when you're done. I'm looking forward to seeing it in that subtle colour, too! ![]() Thanks for looking! |
Author: | Nick Royle [ Sun Jan 26, 2014 9:11 pm ] |
I thought I should show the plan for the bridge, too! Would be useful if anyone could cast their eye over it for me... Attachment: BRIDGE-DESIGN.jpg It's a "wrapover bridge"... Tie a knot in the end of the nylon string and it goes though the hole under the saddle and back out over it. The genius (if I do say so myself ![]() ![]() (The bridge plan isn't totally up to date, I just noticed. The top view is closest to the actual measurements.) |
Author: | johnparchem [ Sun Jan 26, 2014 10:42 pm ] |
Wow! A wonderful project, nicely documented. Thank you sharing this. |
Author: | Nick Royle [ Mon Jan 27, 2014 12:50 am ] |
Thanks for the comment, John! My pleasure to share the pics! A pleasure too to hear such nice feedback! Cheers! Nick |
Author: | Nick Royle [ Tue Jan 28, 2014 7:06 pm ] |
I just checked again post-binding and the difference seems negligible in the low to mid range. The main air resonance is 157hz. Then there are four peaks at 224ish (though it doesn't seem very distinct) 277ish, 373ish, and 471ish... 224 to 277 is just under 4 semitones, so I'm guessing 224 is the top and 277 is the back. But then I don't know what 373 and 471 are. I don't even know if such a small body can be analysed in the same way as a large one?! From there up the peaks have changed position slightly but remain fairly constant... From 2k - 4k there are a decent number of peaks too, so... bright!? |
Author: | Nick Royle [ Fri Feb 07, 2014 1:56 pm ] |
Attachment: image0699.jpg Planing fretboard to size... So much fun! Attachment: image073.jpg Cutting scarf Attachment: image074.jpg Smoothing it Attachment: image075.jpg Gluing head Attachment: image076.jpg Gluing stacked heel Attachment: image077.jpg Gluing head veneer Attachment: image078.jpg Cutting heel |
Author: | Nick Royle [ Fri Feb 07, 2014 2:01 pm ] |
Attachment: image079.jpg Cutting heel to size. (Also note the 1/8th inch deep pocket I routed) Attachment: image080.jpg Installing M6 self tapping threaded inserts... I drilled the holes on my local school's pillar drill. Attachment: image081.jpg Carving primary facets... Love my whittling knife! Attachment: image082.jpg More carving Attachment: image083.jpg Cutting out head shape Attachment: image084.jpg My apologies to the wood gods for wasting maple by using such a large neck blank for such a narrow neck. I wont do it again! (The keen-eyed will notice I put the R on the wrong fret. That was me relaxing my OCD [not that any of my work is usually evident of it! lol] when the going was good.) |
Author: | Nick Royle [ Sun Feb 09, 2014 1:45 pm ] |
The neck is on!!!!!!!!!!!!!!!!!! ![]() ![]() ![]() Attachment: P1070123-SMALL.jpg A million more apologies to the wood gods for using such a wide neck blank... I'll make use of the offcuts!!!! |
Author: | Nick Royle [ Sun Feb 09, 2014 3:40 pm ] |
Couple more pics... (I got excited and just had to post that oen but thought another view or two would be nice.) Attachment: P1070124-small.jpg Attachment: P1070125-small.jpg Attachment: P1070132-small.jpg
Page 1 of 3 | All times are UTC - 5 hours |
