Classical guitar #11 ready for French polish http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10130&t=40873 |
Author: | johnparchem [ Sat Jul 13, 2013 4:44 pm ] |
Post subject: | Classical guitar #11 ready for French polish |
I think I have this guitar ready for French polishing. I have completed my pore fill, found any gaps and spot filled with CA and finally sprayed on a couple of thin coat of blond shellac to act as a sealer. I sprayed the sealer as I sanded the Z-poxy pore fill back to wood and the African blackwood really releases a lot of color. An interesting note is that I cut the fret slots using an LMI template. The nut was cut as if it was a zero slot, and then cut through. Looking at an LMI serviced fret board, I noticed they had a note that said nut slot compensated for kerf width. Measuring I found that there nut position was .4 mm longer than mine. I had some black veneer that was .5 mm so I glued it to the end of the fret board with CA and lightly sanded it smooth. Now I can not measure a difference between my fret board and LMIs serviced fret board. Here are some pictures. ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | Jim Watts [ Sat Jul 13, 2013 6:19 pm ] |
Post subject: | Re: Classical guitar #11 ready for French polish |
John, That looks great. What if any plan is it and is that African Blackwood? |
Author: | johnparchem [ Sat Jul 13, 2013 6:50 pm ] |
Jim Watts wrote: John, That looks great. What if any plan is it and is that African Blackwood? Thanks! Yes it is African Blackwood with Australian Blackwood bindings. It is close to the 37 Hauser plans drawn by Brume for the body, the top is braced as close I could come to Jeffrey Elliott's modification of the 43 Hauser plan he drew. ![]() |
Author: | dzsmith [ Sat Jul 13, 2013 7:49 pm ] |
Beautiful John! Looking forward to seeing it all shiny! BTW, I like your website. My first build was one of those Saga LP's. Your build certainly looks nicer than mine. I played mine a few times, threw it into the closet and started building from scratch. Regards, Dan |
Author: | Murkar [ Thu Aug 22, 2013 2:58 pm ] |
Awesome!! That is a beautiful guitar ![]() ![]() |
