Mandolin Geometry
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10128&t=35587
Author:  George L [ Thu Mar 01, 2012 12:57 pm ]
Post subject:  Mandolin Geometry
Friends,
As noted in various other posts, I'm currently building my first mandolin. I've looked around and haven't found target numbers for the geometry between the neck, bridge/saddle, and strings. I'm at the point where I need to adjust the alignment and set of the neck and I could use some direction.
[Edited to add: This is a simple Army/Navy or campfire style mandolin, so while there is a very slight arch to the top it is basically flat.]
Here's where I'm at right now:
Neck angle = 2 degrees
Fingerboard thickness = .250
Saddle height = .63
When I lay a straightedge along the top of the unfretted fingerboard it hits just at the top of the saddle. If this were a guitar I'd have a good idea as to how I should proceed, but the mandolin is basically a foreign object to me. Am I in the ballpark? Way off the mark? Are there general numbers I should be aiming to hit? Your guidance would be greatly appreciated!
Author:  WudWerkr [ Thu Mar 01, 2012 1:49 pm ]
Post subject:  Re: Mandolin Geometry
Is that an adjustable Bridge/saddle ? If yes , then you are in great shape . When you work off the nut height above the frets at a proper distance and then adjust the bridge accordingly.
Maybe Chris O will pop in and sound off on this thread .
Author:  George L [ Thu Mar 01, 2012 2:21 pm ]
Right now I have a non-adjustable bridge/saddle. I could change that, of course.
Author:  WudWerkr [ Thu Mar 01, 2012 3:05 pm ]
I would say from my limited experience that with a set non adjustable bridge / saddle it would be done the same as a guitar in basic set up. I always use adjustable so I really cant answer with 100% sureness
Author:  Chris Oliver [ Fri Mar 02, 2012 1:30 pm ]
George,
Steve Smith over at Cumberland Acoustic sets is necks on his 'Traveler' model (Army/Navey style) at 1 1/2 degrees and shoots for a 5/8" tall bridge. He uses his Cumberland Acoustic adjustable bridges that have been modified to have the feet shaved off for a shorter bridge with more contact area. He's sells them at a discount from the full blown CA patent bridges.
He said he used to use a steeper angle but the bridges would get too high, causing an excessive break angle and putting too much pressure on the top. He also had to use a fretboard wedge at higher angles.
Hope this helps out.. and do check out Steve's bridges.
Good luck, I've been doing some neck setting myself lately.
Author:  George L [ Sat Mar 03, 2012 10:48 am ]
Chris,
Thanks for the info. That's just what I needed to know. I'll go check out the Cumberland Acoustic site now.
