It is currently Fri Sep 19, 2025 11:42 am
PostPosted: Sat Dec 25, 2010 12:13 pm
First name: Big
Last Name: Jim
I am working on my paduak Mando and I would like to use that material for the fretboard dots . I have searched several places and came up empty . Does anyone make padauk Dowels or Plug/plug cutters ?
Any Suggestions would be appreciated . Last resort is try and hand cut them .
Would like to get to 1/8"
PostPosted: Sun Dec 26, 2010 4:14 pm
James,
How many do you want? Let me know I'll send them your way.
Actually... I'll just be cutting plugs. About 1/2" long each so you can slice off your desired thickness. How many would you like?
chris
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Sun Dec 26, 2010 6:24 pm
First name: Big
Last Name: Jim
pm sent thanks chris !!
PostPosted: Tue Dec 28, 2010 11:00 pm
Dots... made with a counter bore bit with the 1/8" drill bit removed... go figure!
Chris Oliver
Infinity Luthiers
...in the shop.
PostPosted: Wed Dec 29, 2010 9:34 am
First name: Big
Last Name: Jim
Looks like i will be buying some counterbore bits for future use ! Thanks for the idea chris ! and for the effort to make them ! [clap]
PostPosted: Sat Jan 01, 2011 1:33 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Have you got anyone close with a laser engraver/cutter? malls, gift store, bookstore, friend
Childs play if you do.
Simply take them the material thinned to thickness, place masking tape over the material and burn/engrave to desired size ( you may need some backup material if they are really small so they don't fall through the cutting mat). You may need to supply a vector file....... Corel, Turbocad, Autocad, AI or Rhino, or some other vector producing program of what you want.
Kevin
PostPosted: Wed Mar 30, 2011 7:54 pm
First name: Ellison
City: Whitman
State: MA
I have a little trick that I like to use for just this kind of problem. Hopefully it'll help you out!
Take a small piece (any shape) of scrap that is just slightly larger than the size of the dot you want. Now take a drill bit the size of the dot you want. With a dot of CA, glue the piece to the end of the drill bit opposite of the cutting end. Put the bit upside down in a drill press and get it spinning! Now you can take a file, or a sanding block of some sort to the edge of the spinning scrap piece. It'll come out to a perfect circle of the perfect size!
PostPosted: Wed Apr 06, 2011 8:10 am
First name: Big
Last Name: Jim
Sweet ! You should do a short videa toot of that idea and post it . GREAT idea ! [:Y:]
