Ok what Tricks do You Use ?? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10128&t=30238 |
Author: | WudWerkr [ Tue Dec 07, 2010 10:01 am ] |
Post subject: | Ok what Tricks do You Use ?? |
When I wet sanded and buffed my latest effort on a Mando , I either wet sanded to deep or buffed to deep around the head stock on the sharp corners and exposed wood . SOOOO I guess I have to relacq. that area and try again . What Tricks or sugestions do YOU have for keeping the headstock area from Sanding / Polishing to deep ? ![]() |
Author: | Arnt Rian [ Tue Dec 07, 2010 3:08 pm ] |
Post subject: | Re: Ok what Tricks do You Use ?? |
Stay away from the corners! ![]() |
Author: | tlguitars [ Tue Dec 07, 2010 3:26 pm ] |
Ignore them completely. |
Author: | WudWerkr [ Tue Dec 07, 2010 3:33 pm ] |
Could it be that simple ?? ![]() |
Author: | tlguitars [ Tue Dec 07, 2010 6:57 pm ] |
"Ignore them completely" is a mental trick. I wet sand my "top," not the "corner." I wet sand my "side" not the "corner." When I buff, I buff the top and stay off the edge, getting to say an 1/2- 1" inch away from the edge, "pert-near up-on," that way the feather of the buffer can buff the corner without me "trying" cuz I'm focused on the area that is 1/2 to an inch away. Double pass your corners. If your spraying your top: I do a vertical pass across, across, across, across, across until the face is covered then I do a horizontal pass that splits the edge all the way around to "Frame it in." That way you "double your corner build" (each top coat is then the equivalent of 2 passes) so when it dries and you sand and buff there's that much more to help against burn throughs. |
Author: | WudWerkr [ Wed Dec 08, 2010 9:51 am ] |
Quote: "Ignore them completely" is a mental trick. I wet sand my "top," not the "corner." I wet sand my "side" not the "corner." When I buff, I buff the top and stay off the edge, getting to say an 1/2- 1" inch away from the edge, "pert-near up-on," that way the feather of the buffer can buff the corner without me "trying" cuz I'm focused on the area that is 1/2 to an inch away. Double pass your corners. If your spraying your top: I do a vertical pass across, across, across, across, across until the face is covered then I do a horizontal pass that splits the edge all the way around to "Frame it in." That way you "double your corner build" (each top coat is then the equivalent of 2 passes) so when it dries and you sand and buff there's that much more to help against burn throughs. Ive been spraying my mandos that way ![]() ![]() ![]() ![]() |
Author: | Parser [ Fri Dec 10, 2010 7:49 pm ] |
Another thing that helps is to not have sharp corners...! I round off my corners, even if just a little bit. trev |
