mando neck joint http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10128&t=27151 |
Author: | fric [ Mon Apr 26, 2010 4:56 am ] |
Post subject: | mando neck joint |
hi, I want to build my first mando... it will be flat top, scale 361mm etc where I nead some advice is about neck joint type in mando (some pic, or drawing or....) regards Fric |
Author: | WudWerkr [ Mon Apr 26, 2010 8:43 am ] |
Post subject: | Re: mando neck joint |
I usea a standard straight tennon joint as the pics show , These pics are NOT a finished tennon , but give you the basic idea . I use a long drywall screw from inside the box to pull it in tight while glue dries and when its done I remove the screw drill the hole out a little larger and glue a dowel in its place . Keep in mind IM NOT A PRO ! This is just what works for me . Attachment: 100_0284.jpg Attachment: 100_0286.jpg
