Rattle can suggestions — gloss black http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=55726 |
Author: | rlrhett [ Sat Jun 17, 2023 10:52 pm ] |
Post subject: | Rattle can suggestions — gloss black |
I never do solid colors, but my niece has asked for a gloss black electric guitar. Can anyone recommend a rattle can for applying a solid black base coat. I will likely add a Mohawk clear lacquer top coat (although I’m always open to suggestions for getting a good solid black high gloss finish). Why rattle can? I’m just assuming it is the cheapest way to get a one-guitar solution. Educate me, please, if I’m wrong. Perhaps lacquer is wrong, and I should go with some automotive finish? One of those spray cans where you slam the bottom to release a catalyst? In any case, twenty years of trying to apply the thinnest finish possible and make the wood’s beauty shine through hasn’t prepared me for this request. Sent from my iPhone using Tapatalk Pro |
Author: | joshnothing [ Sat Jun 17, 2023 11:43 pm ] |
Post subject: | Re: Rattle can suggestions — gloss black |
If you are experienced with gloss nitro stick with nitro. Stewmac has black nitro rattlecans and Mohawk do too. If you’ve got a spray gun, just add a little black pigment to whatever lacquer you normally spray. Lampblack is pretty cheap. Sent from my iPhone using Tapatalk |
Author: | Chris Pile [ Sat Jun 17, 2023 11:56 pm ] |
I buy Tamiya acrylic lacquer in the rattle can at Hobbytown, USA. |
Author: | Hesh [ Sun Jun 18, 2023 2:55 am ] |
Second the StewMac black rattle can, nice stuff. I've found the last 1/3 of the cans spit though at least mine did. Disrespectful things can't take them anywhere but I digress. So maybe buy enough with the idea that you will want to toss the last 1/3 of each can instead of be upset with what happens next.... ![]() |
Author: | dzsmith [ Sun Jun 18, 2023 4:49 pm ] |
Stewmac rattle can worked well for me. If you spray through a gun, Mixol pigment can be added. Local Woodcraft sells Mixol. I used black dye on bare wood, sprayed black Mixol in lacquer, then clear coat. Don’t fret when polishing. It’s impossible to remove swirl marks. |
Author: | rlrhett [ Sun Jun 18, 2023 6:13 pm ] |
Will Mixol make it opaque? I have Trans Tints, but I didn’t think I would get an opaque base coat with dyes. Sent from my iPhone using Tapatalk Pro |
Author: | joshnothing [ Sun Jun 18, 2023 6:22 pm ] |
Mixol will get you an opaque result if you use enough of it. Sent from my iPhone using Tapatalk |
Author: | Barry Daniels [ Mon Jun 19, 2023 7:43 am ] |
Mixol is not really a dye like Transtint, but more of a stain or colorant. |
Author: | Chris Pile [ Mon Jun 19, 2023 10:47 am ] |
It's not a guitar - but it's painted with Tamiya gloss black lacquer from a rattle can... https://i.imgur.com/xEilJ4p.jpg |
Author: | rlrhett [ Mon Jun 19, 2023 12:10 pm ] |
Chris Pile wrote: It's not a guitar - but it's painted with Tamiya gloss black lacquer from a rattle can... https://i.imgur.com/xEilJ4p.jpg That is very nice. Is there clear gloss on top, or the straight black? Sent from my iPhone using Tapatalk Pro |
Author: | Chris Pile [ Mon Jun 19, 2023 1:09 pm ] |
Straight black. |
Author: | dofthesea [ Mon Jun 19, 2023 5:23 pm ] |
Stewmac and Allparts has Black in a rattle can. |
