It is currently Fri Jul 18, 2025 12:43 pm
PostPosted: Thu Jun 18, 2020 4:43 pm
First name: Jeff
Last Name: McKim
City: Graham
Zip/Postal Code: 98338
I'm building a really thin guitar based on the old Epiphone Coronet (solid body). I'm splitting each humbucker coil set via a push/pull pot. I'm using CTS #450S 3910 because they're fairly well reviewed and quite short compared to most PP's.
I have a question. The tops of these have upturned "ears" that hold the body slightly away from the inside of the control cavity...or they are pressed into the body to further secure the pots - I don't know which is correct although I'm hoping for the latter as that allows the pots to fit in the body with about a 1/16th" to spare.
In the pic below, the ears I'm talking about are circled in the center pots.
thanks.
PostPosted: Thu Jun 18, 2020 5:14 pm
The upturned ear is designed to fit in a hole in the plate the pot
is mounted on so that the pot won't turn if nut gets loose.
You can press them into the body.
These users thanked the author SteveSmith for the post: Hesh (Fri Jun 19, 2020 6:06 am)
PostPosted: Fri Jun 19, 2020 6:06 am
And CTS is great stuff, we consider it the best and have installed hundreds and hundreds of them with never a single issue.
PostPosted: Fri Jun 19, 2020 11:03 am
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I just clip those off with wire cutters if they're in the way.
