What size machine screws for bolt on necks http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=51240 |
Author: | dofthesea [ Sat Nov 17, 2018 8:46 pm ] |
Post subject: | What size machine screws for bolt on necks |
So I'm going to start using threaded. inserts and machine screws to bolt on my Fender style necks. Thinking bout 10-32 with 4 total. Why are you guys using for this application? Brass or aluminum inserts? |
Author: | DavidSchwab [ Sat Nov 17, 2018 9:30 pm ] |
I use 10-32 screws. I use steel or brass inserts. This guitar has steel. ![]() Sent from my iPhone using Tapatalk |
Author: | Conor_Searl [ Sat Nov 17, 2018 10:29 pm ] |
Post subject: | Re: What size machine screws for bolt on necks |
Rookie question... When you say inserts are you talking about inserts that are anchored in the actual neck? And if so what is typically used to glue them in, or are they even glued? |
Author: | Chris Pile [ Sat Nov 17, 2018 11:43 pm ] |
Not aluminum. Prone to galling, and also prone to corrosion causing seizing. |
Author: | dofthesea [ Mon Nov 19, 2018 12:31 am ] |
Conor. inserts that are anchored in the neck. The machine screws go through the body type with a grommet. |
Author: | RogerC108 [ Mon Nov 19, 2018 9:09 am ] |
deleted. Mis-read question. |
Author: | DavidSchwab [ Mon Nov 19, 2018 10:39 am ] |
Conor_Searl wrote: Rookie question... When you say inserts are you talking about inserts that are anchored in the actual neck? And if so what is typically used to glue them in, or are they even glued? Yes. They aren’t glued in. The have sharp threads that screw into the hole. ![]() https://www.rockler.com/steel-threaded- ... elect-size Sent from my iPhone using Tapatalk |
