It is currently Fri Jul 04, 2025 1:29 am
PostPosted: Fri Jun 17, 2016 11:11 am
First name: James
Last Name: Sturner
City: Newtown
State: PA
Zip/Postal Code: 18940
So I'm working on my first project. I started with a base coat, followed by a couple of coats of primer and blue rusto spray paint, followed by miniwax Nitro lacquer from a rattle can. As I was wet sanding, I went through the lacquer and paint along some of the contours. What would be the best way to fix this?. The areas are very small but I would like to fix them the right way. Should I sand through the whole thing or is there a goodbye aye to do small touch ups? Thanks!
PostPosted: Fri Jun 17, 2016 1:13 pm
City: Tyler
James, were all the products lacquer based? Is blue rusto lacquer?
PostPosted: Fri Jun 17, 2016 2:21 pm
First name: James
Last Name: Sturner
City: Newtown
State: PA
The rustoleum is Painters Touch ultra cover 2x enamel spray paint.
PostPosted: Fri Jun 17, 2016 6:26 pm
City: Tyler
You take a risk, IMO, to apply nitro over enamel. It can cause adhesion problems that might not show up for months. I know this the hard way. I'm not sure how risk-adverse you might be, so what to do now kind of hinges on that.
PostPosted: Fri Jun 17, 2016 6:52 pm
Mr. Turner.... best not to mix finishes.... especially nitro with anything else.
PostPosted: Fri Jun 17, 2016 6:58 pm
First name: James
Last Name: Sturner
City: Newtown
State: PA
So should I sand everything back to wood?
PostPosted: Sat Jun 18, 2016 6:00 am
That would be my option. Sand back and use nitro base, colour and then clear over the top.
Sent from my Nexus 7 using Tapatalk
PostPosted: Sat Jun 18, 2016 3:22 pm
City: Tyler
I'd use stripper, but that's just me.
