Sanded through nitro and paint
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=47912
Author:  Jsturner [ Fri Jun 17, 2016 11:11 am ]
Post subject:  Sanded through nitro and paint
So I'm working on my first project. I started with a base coat, followed by a couple of coats of primer and blue rusto spray paint, followed by miniwax Nitro lacquer from a rattle can. As I was wet sanding, I went through the lacquer and paint along some of the contours. What would be the best way to fix this?. The areas are very small but I would like to fix them the right way. Should I sand through the whole thing or is there a goodbye aye to do small touch ups? Thanks!
Author:  Glen H [ Fri Jun 17, 2016 1:13 pm ]
Post subject:  Re: Sanded through nitro and paint
James, were all the products lacquer based? Is blue rusto lacquer?
Author:  Jsturner [ Fri Jun 17, 2016 2:21 pm ]
The rustoleum is Painters Touch ultra cover 2x enamel spray paint.
Author:  Glen H [ Fri Jun 17, 2016 6:26 pm ]
You take a risk, IMO, to apply nitro over enamel. It can cause adhesion problems that might not show up for months. I know this the hard way. I'm not sure how risk-adverse you might be, so what to do now kind of hinges on that.
Author:  Chris Pile [ Fri Jun 17, 2016 6:52 pm ]
Mr. Turner.... best not to mix finishes.... especially nitro with anything else.
Author:  Jsturner [ Fri Jun 17, 2016 6:58 pm ]
So should I sand everything back to wood?
Author:  GourmetSaint [ Sat Jun 18, 2016 6:00 am ]
That would be my option. Sand back and use nitro base, colour and then clear over the top.
Sent from my Nexus 7 using Tapatalk
Author:  Glen H [ Sat Jun 18, 2016 3:22 pm ]
I'd use stripper, but that's just me.
