It is currently Mon Aug 25, 2025 1:22 am
PostPosted: Wed Apr 10, 2019 12:47 pm
First name: Big
Last Name: Jim
Playing with a Mulberry and Cherry Electric . Yes that is a factory Neck . I have made the body by hand and Had the neck to work with . Mulberry is heavy wood .
PostPosted: Thu Apr 11, 2019 6:18 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
White or red mulberry?
Brian
PostPosted: Thu Apr 11, 2019 4:18 pm
First name: Big
Last Name: Jim
I agree with your thought on PM that it looks like Osage Orange . However I have never seen osage that big before . was 19" wide in orig board . Mill Owner has a tree service , swears its Mulberry . Verrryyyy Heavy !
PostPosted: Thu Apr 11, 2019 7:10 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I’ve never handled mulberry before but it is supposed to look very similar to Osage. Osage orange is quite a bit denser than mulberry. Mulberry is reported to have a specific gravity of 0.69 compared to osage’s 0.86 so it is almost 25% heavier. Wud, have you ever used Osage to compare the density?
With a board that size and the sawyer knowing it in log/tree form. I’d think it is not Osage. A good way to tell for sure is to soak some shavings in water. Osage will dye the water yellow.
Bryan Bear PMoMC
PostPosted: Fri Apr 12, 2019 12:26 pm
First name: Big
Last Name: Jim
Per that Test it is Mulberry .
These users thanked the author WudWerkr for the post: Bryan Bear (Fri Apr 12, 2019 12:26 pm)
