Best double-sided tape for affixing templates? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=44600 |
Author: | dzsmith [ Mon Nov 17, 2014 9:00 pm ] |
Post subject: | Best double-sided tape for affixing templates? |
Hey fellers, what is a good brand of tape? I have not been cutting with templates lately due to mishaps. Thanks, Dan |
Author: | Chris Pile [ Tue Nov 18, 2014 12:08 am ] |
Post subject: | Re: Best double-sided tape for affixing templates? |
I just buy whatever double-sided carpet tape the hardware store across the street has in stock. |
Author: | Fred Tellier [ Tue Nov 18, 2014 10:36 am ] |
The best I have found is the 3M tape StewMac sells, I went through several different store brands but on trying this tape it was much superior in its hold. I do a lot of template operations and have not had any movement issues with it. Can be a bit of a pain to separate but this is a good thing in my mind. Fred |
Author: | Tim Mullin [ Tue Nov 18, 2014 2:08 pm ] |
This question made me smile. I've been using Sellotape brand ever since I started building guitars in New Zealand. Readily available at home improvement centres in a variety of widths: http://www.sellotape.co.nz/products/stationery/tapes/double-sided/63-double-sided-general-purpose.aspx I never thought it was anything special, until I tried to buy something similar in Canada and the US, and really couldn't find anything comparable in home improvement or stationery stores. I went back to NZ last Christmas for the birth of my grandson, and stocked up on Sellotape while I was there. |
Author: | dzsmith [ Tue Nov 18, 2014 5:32 pm ] |
Thanks for the replies! Dan |
Author: | JimO [ Tue Nov 18, 2014 5:58 pm ] |
Yes! I had to cut out a neck and replace it on a bass due to tape that slipped while routing. Will check it out. |
Author: | Freeman [ Tue Nov 18, 2014 9:51 pm ] |
While I use 3M tape I also try to back it up with a screw or clamp. |
Author: | Burton LeGeyt [ Wed Nov 19, 2014 9:58 am ] |
The best I have used is the 3M 9589. That is what I buy for students at work and it has never failed. My home shop budget though usually goes for the hardware store carpet tape ![]() |
Author: | dzsmith [ Wed Nov 19, 2014 6:49 pm ] |
I reckon I'll order some from Stewmac. I have used carpet tape, but it's a hassle getting the goo off. Thanks! Dan |
Author: | John Sonksen [ Thu Nov 20, 2014 12:33 am ] |
I've been using Fasttape from Fastcap. It sticks great, kind of a pain to peel the paper off the one side and really a pain to get off your wood. Sticks like crazy though, I think it's sold as adhesive for applying cabinetry edgebanding, and it claims to be permanent. It's not, if you have a putty knife and a scraper, lol. |
Author: | klooker [ Thu Nov 20, 2014 7:19 am ] |
I use Itape 591. It's like double sided masking tape. It is strong, relatively easy to remove, doesn't shred and leaves no residue. I get it from McMaster, their p/n is 76405A12 for 3/4". Kevin Looker edit: It's relatively easy to remove unless you put the parts in a vacuum press DAMHIKT ![]() |
Author: | Sandywood [ Thu Nov 20, 2014 6:46 pm ] |
Another vote for the StewMac tape...good stuff. It can be a little work separating the pieces and removing the tape but I found it's easier to roll the tape off rather than trying to pull it off. |
Author: | SteveSmith [ Thu Nov 20, 2014 8:54 pm ] |
I use the StewMac tape. A little Naptha will make the tape release easily. |
