It is currently Tue Jul 22, 2025 2:40 am
 Post subject: Control knows,
PostPosted: Sat Nov 08, 2014 6:22 pm
Last Name: Ward
Country: UK
Could any of you kind folks, tell me how you go about inserting the control knobs, in particular how you round the corners afterwards.
I have a very always drilled the incident with a forstner bit, then put the hole through for the potentiometer. Finally I run a bearing guided round over router bit, with the bearing removed around the pot hole. It does limit the size of the indent though, hence my query.
Edited to make allowances for song's feeble attempt at predictive text.
 Post subject: Re: Control knows,
PostPosted: Sun Nov 09, 2014 9:01 pm
First name: D
Last Name: S
Chris, I've done it the same as you with a round over bit.
I can't think of any other tool I have that would work better.
wah
Wah-wah-wah-wah
Wah
