It is currently Mon Jul 28, 2025 1:17 pm
PostPosted: Wed Mar 26, 2014 3:15 pm
On a recent test I did with 2x4s, I made a butcher blocked body with each piece cut with a concave curve by the band saw. Then I glued them together, but it was a lot of work getting the pieces leveled out. My finger planes did not have a curved bottom, and scraping and sanding was going way too slow. Should I buy a bent (curved) chisel or round bottom plane, or other idea ? The attached pic shows an idea of hanging a router over the block. Thanks.
PostPosted: Wed Mar 26, 2014 4:38 pm
Online
Get yourself a Four-in-hand rasp. It has a curved face, and a flat face - with rasp teeth on one end, and bastard file teeth on the other. Works like a charm.
http://www.leevalley.com/en/images/item ... 901s1b.jpg
PostPosted: Wed Mar 26, 2014 5:05 pm
Maybe a scorp.
http://www.woodcraft.com/product/2001825/1305/pfeil-swiss-made-scorp.aspx
PostPosted: Thu Mar 27, 2014 7:59 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Gouge out the majority with chisels and refine with rasps, scrapers and sandpaper. An approach like this will also allow you to vary the shape of the contour in all three dimensions to create something that looks nice but also feels comfortable. With a jig as suggested you are stuck creating a straight cylindrical relief and nothing more.
Brian
PostPosted: Thu Mar 27, 2014 1:21 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
The router idea just looks dangerous to me. I'd do it like one of the usual archtop methods.... 1; Drill to specific depths at the edges, middle, center. Then use the holes as a guide for carving. Or 2; use a router and templates to cut terraced depths (like a stair case) then carve away the steps until smooth.
PostPosted: Fri Mar 28, 2014 10:43 am
First name: sean
State: nm
Zip/Postal Code: 88349
Country: us
Well, if it were me, I would mount it in the mill and cut terraces inward. For rough carving I use an angle grinder with a 40 grit flapper wheel (works great and FAST for alder, decent for maple, but burns mahogany pretty quick). When I hit wood that burns easy, I just take small bites or hit it with an air compressor blow gun while I carve to keep the wheel cool.
You could carve most of it out with a flapper. I am pretty precise with one and even carve necks with one, but I had lots of practice with and angle grinder after a decade of ugly welding. I am also not past pulling out a chainsaw to carve, I guess my methods are pretty unconventional.
Whatever you do DON'T confuse me as an EXPERT, or MASTER, just a self learned trial and error guy. I had to build a dozen guitar before I found out what a "Luthier" even was (????)
PostPosted: Fri Mar 28, 2014 11:31 pm
First name: Van
Last Name: Savage
City: Marion
State: AR
Zip/Postal Code: 72364
I agree with using the angle grinder.
PostPosted: Sat Mar 29, 2014 7:26 pm
First name: Patrick
Last Name: Hanna
State: Missouri
You've got good suggestions from everyone and a particularly good insight from Brian Howard. If I were doing it, I would go with the gouge, round bottomed plane, scorp, scraper method. The reason I would do this is because I'd rather make shavings than dust and chips. And I would rather hear the hand tool blade against the wood than listen to the motor of a power tool. That's just what I would do. It doesn't mean the other ways aren't valid. They are. And, yes, I use power tools all the time for precision and repeatability, and sometimes getting out working stock. But I much prefer to make shavings in a case like this.
Patrick
