neck holes http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=43072 |
Author: | mlucas123 [ Thu Mar 27, 2014 5:54 pm ] |
Post subject: | neck holes |
I'm currently working on a double cutaway (solid body) project. It was a cheap body I bought. I need some suggestions on how to go about with the neck holes. The heel is cut away and so one of the holes has been drilled in closer. I have found a neck plate on amazon that might do the job but its being shipped from china and it says its going to take about a month to get here. I also have bushings that I could possibly use. Anybody have any other suggestions or any advice? |
Author: | dzsmith [ Thu Mar 27, 2014 7:43 pm ] |
Post subject: | Re: neck holes |
I think Stewmac has some ferrules that are used under the screw heads withou using a plate. Part number 4184 |
Author: | funkymann1 [ Sat Mar 29, 2014 1:04 pm ] |
the bottom holes look wider in that pick, if so you have no choice but to use bushings.... something like this would work: http://www.ebay.com/itm/Guitar-Neck-DIY ... 3f2f3f947f or you can just buy some neck screws & see if the local hardware store has some kind of ferrules... |
