It is currently Fri Jul 25, 2025 6:45 pm
PostPosted: Fri Oct 25, 2013 2:14 pm
First name: Stuart
Last Name: Gort
After using around forty of them I've found three or four that are scratchy...or rather, the signal is scratchy upon use. That's kind of a bad track record in my book.
I'm wondering...are there are any "elite" manufacturers of pots?
StuMusic
PostPosted: Fri Oct 25, 2013 2:45 pm
At the risk of PO'ing Filippo, I'd offer Allen-Bradley as a premium potentiometer.
Or Bournes...
PostPosted: Fri Oct 25, 2013 3:47 pm
City: chicagoland
State: illinois
....you can always used a "stepped" pot, if you want to spend 100 bucks or so on one pot. instead of a wiper, it ratchets through dozens of fixed value resistors of decreasing value....that will definitely solve intermittant contact, or "scratchiness", but it is extreme overkill
PostPosted: Fri Oct 25, 2013 5:22 pm
First name: D
Last Name: S
Do NOT purchase Bourns Pro Audio pots.
I had one with an open wiper, and one hex nut was too thin to tighten - it only had one thread.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Oct 28, 2013 9:12 am
First name: James
Last Name: Tonguet
City: Duluth
State: Ga
Zip/Postal Code: 30096
I've used Bourne Pro-audio pots on a few , I like them a lot , though a bit pricey
PostPosted: Wed Oct 30, 2013 9:32 am
First name: Rand
Last Name: Kennedy
State: CO
I have not had any issues with the quality of the CTS pots but mostly have used boutique ones from RS for the taper. The WD and Stewmac ones have also been trouble free. Bad manufacturing run or contamination (Deoxit ?)? Have you taken one apart to look at the substrate ?
PostPosted: Fri Nov 01, 2013 5:57 pm
Store do you want him to turn down fast or do you prefer more linear
Ken
Ken
PostPosted: Fri Nov 01, 2013 5:58 pm
Hi my speak and spell wrote your name down as store sorry Stuart
Ken
Ken
PostPosted: Sat Nov 02, 2013 11:11 am
First name: Stuart
Last Name: Gort
Ken
Doesn't matter to me...I expect a fellow that does volume swells with his finger would probably want audio pots but fro now...I don't care.
StuMusic
PostPosted: Sun Nov 03, 2013 9:10 pm
We'll then buy a big lot of pots from all parts. Cts are good but you can measure them. Make a test rig so you can ohm them and match within ten percent. But most importantly chech to see if they are crackly.
Ken
Ken
PostPosted: Tue Nov 05, 2013 10:40 am
First name: Rand
Last Name: Kennedy
State: CO
CTS and Bourns don't make cheap junk parts, they are ISO 9k and they make parts that meet their specs although we might want parts with better specs. They only know about failures of shipped parts if they come back to them from the distributor.
CTS doesn't spec out noise, Bourns does on their low-end parts, so there's not much to go back on with that. If you've got a pile of them you can't use I'd recommend making sure the distributor knows and maybe something will change. They have a new 450G series with the right shafts, tighter tolerance and several tapers but they don't list a noise spec on those either. http://www.ctscorp.com/components/Datasheets/450g.pdf
Since Bourns and CTS now offer guitar specific products at least there are two to choose from and maybe they'll continue to make better quality stuff with the competition.
