neck through belly http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=41718 |
Author: | wesrichards [ Sat Oct 19, 2013 11:19 am ] |
Post subject: | neck through belly |
should i sand down a slight belly in the neck to compensate for fret deflection , the neck wood is African mahogany with a ebony fret board ,22 frets. |
Author: | Frank Cousins [ Thu Oct 31, 2013 2:53 pm ] |
Post subject: | Re: neck through belly |
wesrichards wrote: should i sand down a slight belly in the neck to compensate for fret deflection , the neck wood is African mahogany with a ebony fret board ,22 frets. If your neck is straight - and your fretboard flat when glued down - then when you fret it you should see a slight back bow to the neck as a result of the fret tangs being wider that the fret slot - I would leave this well alone as pretty normal - when you string, the tension will straight the neck and the rest is then managed with the trsus rod. Should be no need to 'sand' the fretboard in any place - just get them nice and straight before you glue up or fret. |
Author: | theguitarwhisperer [ Fri Nov 01, 2013 11:05 am ] |
Depends on if you're using a double action truss rod or not. Some guys like to put a small hump in the neck nd flatten it out before radiusing to assure relief in the neck after fretting. |
Author: | dzsmith [ Fri Nov 01, 2013 6:01 pm ] |
theguitarwhisperer wrote: Depends on if you're using a double action truss rod or not. Some guys like to put a small hump in the neck nd flatten it out before radiusing to assure relief in the neck after fretting. That's what I do when using a single-action rod. I glue my fret board blank to the neck, level the board, create a slight hump, re-level the board, saw frets, taper, radius, polish, apply finish (if desired) and then install the frets. I've used stiff wood like Mesquite for necks and I want to ensure I can get relief. It may be overkill but it works for me. Dan |
