New guy with a new hobby http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=41695 |
Author: | klooker [ Wed Oct 16, 2013 7:19 pm ] |
Post subject: | Re: New guy with a new hobby |
Welcome Eric. Thanks for sharing some pics. I've built 5 acoustics & one Les Paul. Personally, I enjoy building the acoustics more. Although most would say more work, I think they're easier. Kevin Looker |
Author: | Quine [ Thu Oct 17, 2013 12:40 pm ] |
Sweet. I like the color on the burst |
Author: | emoney [ Thu Oct 17, 2013 2:56 pm ] |
Thanks all. And I guess it's all perspective, but building the acoustic sure seems more daunting to me, lol. Then again, building anything at all seemed rather daunting in the beginning. I've purchased some Sapele sides already bent, so I will have a little bit of a headstart. I've got a lot of reading to do, that much is for sure. The only thing I'm really struggling with, mentally at the moment, is the angle for the neck. I see how it's desired, and understand why, but is it all cut into the tenon/heel or does the the slope of the guitar encompass it? Lots of beautiful guitars getting built around these parts, thats for sure! |
Author: | klooker [ Thu Oct 17, 2013 4:55 pm ] |
Not sure how everyone else does it, but I cut the angle of the heel at 89 degrees, then fine tune it with chisels, shoulder rabbet plane & sandpaper. For me acoustics are less stressful because you build each component, then put them together. You can also take them back apart if needed. ...except for routing the binding channels. With an electric, I get stressed out routing the neck pocket, pickup cavities & positioning the bridge. One mess up & you have to decide if it's salvageable or time to start over. Kevin Looker |
Author: | emoney [ Thu Oct 17, 2013 7:33 pm ] |
So, if I'm understanding you, Kevin, you just cut 1 degree in the "face" (where it sits against the body), and I'm guessing towards the headstock? If I can ask one more question; what actually "curves" the top on an acoustic? I know that there are "flat-tops" and "non-flat" flat tops (wow, that's definitely a rookie worded question, eh?), but is it the brace that you're carving to get the curvature? -Eric |
Author: | klooker [ Fri Oct 18, 2013 8:51 am ] |
Yes, I make the angle of between the top of the neck & the shoulders of the neck tenon 89 degrees to start. Flat tops are usually not really flat. They are domed somewhere between a 28 and 40 foot radius. This is accomplished by radiusing the under side of the braces. Most people then glue the braces to the top in a radius dish but some do it on a flat bench & the top will spring back after removing the clamps. Either buy, or see if your library has a copy of Guitarmaking Tradition and Technology by Cumpiano. Kevin Looker |
Author: | emoney [ Fri Oct 18, 2013 9:34 am ] |
Perfect, and thanks for the book recommendation. I'm planning to head to the book store tomorrow and now I have a title to look for! |
Author: | klooker [ Fri Oct 18, 2013 11:17 am ] |
Here's some more info http://www.kennethmichaelguitars.com/NECKSET.html Kevin Looker |
Author: | Mike Baker [ Fri Oct 18, 2013 6:35 pm ] |
Welcome, Eric. Love the LP. |
