It is currently Wed Jul 23, 2025 9:13 am
 Post subject: Color Coats
PostPosted: Mon Jun 17, 2013 4:07 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I'm planning to build my first electric guitar. I've made numerous acoustics and have the finishing down pretty well. I intend to spay a nitrocellulose lacquer for this guitar. My question is, how do you apply a color coat? Say I'm looking for a nice dark red- can I just stick a couple coats of paint I got down at autozone between the sealer and the topcoat or is there another way? Sorry if this question is super novice but I wanna make sure I don't have adhesion issues.
 Post subject: Re: Color Coats
PostPosted: Mon Jun 17, 2013 4:30 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
The "normal" way is to mix the color with the lacquer and spray color coats until you get it as dark as you want, then clear lacquer over that. The best way to figure this out is to test on scrap first, that's a lot less painfull than sanding all the color off a guitar.
edit: the stuff from autozone is probably acrylic lacquer, and may not be compatable with nitro lacquer.
PostPosted: Tue Jun 18, 2013 6:32 am
Depends. Translucent? Either stain the wood directly or tint the lacquer, and cover with clears. Solid colors will want a pigment instead of stain. StewMac carries both (rebranded transtint stains as well as pigments for solid colour jobs). That's the safest way to do it - stick to a single paint system and don't mix and match too much.
Whatever you do, test your finish schedule on scrap first.
PostPosted: Tue Jun 18, 2013 7:40 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Apply the color coats right over your sealer. Then clear as normal.
Brian
PostPosted: Wed Jun 19, 2013 10:31 am
First name: Stuart
Last Name: Gort
For transparent tints, Transtint dyes are great in lacquer.
For opaque colors, Mohawk makes an extensive line of powder based pigments for lacquer.
I'd emphasize making sure your have your wood thoroughly sealed and smooth prior to applying the color coats. The smoother it goes down when spraying, the better the finished result.
StuMusic
PostPosted: Thu Jun 20, 2013 7:46 am
The look of colors applied directly to the wood with clear coats on top is quite defferent than colors over a sealer, or in the laquer. It also has its own set of challenges. Anyways, all this will become clearer when you test on scrap, so make sure you test until you know what you want and how to get there.
