It is currently Thu Sep 18, 2025 10:14 pm
PostPosted: Sun Jan 20, 2013 11:53 am
First name: Darren
Last Name: Galloway
City: Benton
State: IL
Zip/Postal Code: 62812
I have read a lot about this wipe on poly for maple necks and thought I would give it a try. I have a neck that I have prepared for nitro with sanding sealer and decided that with the weather in my area it would be a while before I could shoot nitro (ventilation). I was thinking about doing Tru Oil but since there is sanding sealer on the neck I was worried about the oil not penitrating. So what about this Minwax Wipe on Poly? Has anyone out there used it and will it work with sanding sealer? What is your technique?
I wanted something very dense, something that would sustain long and more pieces of wood that would be soft, sweet, for more of a mellow sound.
~ Les Paul
PostPosted: Sun Jan 20, 2013 12:10 pm
First name: Stuart
Last Name: Gort
I would worry about ANYTHING underneath it. It took some time before I got it to work predictably on bare wood. I wouldn't presume to suggest it was going to work over any substrate material without testing it thoroughly.
StuMusic
PostPosted: Sun Jan 20, 2013 2:03 pm
Hey Bluesman,
I agree with Zlurgh, chances are the sanding sealer you used is going to be a problem. To make sure, I suggest you apply a couple of coats of dewaxed schellac (I use Zinsser seal coat). Schellac is one of the rare thing polyurethane sticks to.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed Jan 23, 2013 6:40 pm
First name: Darren
Last Name: Galloway
City: Benton
State: IL
Thanks for the tips.
~ Les Paul
