It is currently Fri Sep 19, 2025 10:02 pm
 Post subject: Making your own knobs...
PostPosted: Tue Dec 13, 2011 7:41 pm
First name: Virgil
Last Name: Mandanici
State: FL
One of the things I can't seem to track down is the setscrews/sleeves needed and any type of inserts for making your own knobs - anyone out there have any suggestions? On the dueling dragons, I took an old set of fender vol/tone knobs and glued them into the bottom of the custom wood kobs I made (After grinding them down with my Dremel)- any experience/suppliers would be appreciated!
PostPosted: Tue Dec 13, 2011 7:55 pm
First name: Alex
Last Name: Takacs
State: Illinois
You can probably get set screws at your local hardware store, or here http://www.mcmaster.com/#set-screws/=fcne8j for guitar knobs, I would recommend the cup point, the knurled cup point, or the cone point.
PostPosted: Tue Dec 13, 2011 7:58 pm
ACE is the place, bro.
PostPosted: Wed Dec 14, 2011 2:59 am
First name: Jim
Last Name: Hansen
Someone already mentioned McMaster-Carr. You might check McFeely's too.
I get that stuff locally at "Tacoma Screw", but I've never ordered from them online.
http://www.tacomascrew.com/products/search/set%20screw
Jim Hansen
PostPosted: Wed Dec 14, 2011 10:26 am
First name: shad
Last Name: peters
I have always wondered if there were somewhere that you could get nurled inserts for that, but If there is I haven't found it. as far as set screws I just bought mine from fastenal, they carry them all the way down to #4 I think, and they have an outlet within walking distance of my house.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Wed Dec 14, 2011 10:42 am
Something like that?
http://www.ebay.com/itm/BUSHING-PARTS-M ... 385wt_1398
or like that:
http://www.ebay.com/itm/SET-PARTS-MAKIN ... 484wt_1398
Obviously, I have NO affiliation with the Ebay seller... but I have bought from them in the past and was pleased with the quality of the products!
PostPosted: Wed Dec 14, 2011 11:14 am
First name: Virgil
State: FL
or like that:
Yes- this is what I was looking for - I did find something similar at the local Lowe's but they are pricey - Do you guys feel that the allen wrench for them should be supplied with a guitar or not?
PostPosted: Wed Dec 14, 2011 11:19 am
First name: Roger
State: Oklahoma
I wouldn't think that would be necessay, Virgil. I know I've got tons of allen wrenches in the tool box from various sources, so I'd probably have one that would work anyway, but maybe I'm not like most people idunno
PostPosted: Wed Dec 14, 2011 11:26 am
First name: David
Last Name: Morris
City: McKinney
If they're on a completed guitar, I'd say no. You would include everything needed to perform a setup, but in theory, the knobs are permanently installed. If you were selling knobs a la carte, I'd think a wrench might be included.
David Morris
PostPosted: Wed Dec 14, 2011 6:28 pm
First name: Patrick
Last Name: Hanna
State: Missouri
If you're making hardwood knobs (I presume you're making wood knobs) then I don't think you need any inserts. A hardware store set screw ought to be just fine, and will probably even self-tap its own hole if the hole is sized right. But you might not even need a set screw. I made a walnut knob for the volume control on my archtop and simply pressed it onto the pot shaft. That was three years ago and it's still on there tight--and straight, too. I figured if it ever loosened up, I could add a set screw at that point. Thus far, unnecessary.
Patrick
PostPosted: Wed Dec 14, 2011 6:39 pm
First name: Virgil
State: FL
Very cool tip Patrick!
