| Official Luthiers Forum! http://mowrystrings.luthiersforum.com/forum/ |
| Bridge placement http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=33390 |
| Author: | Panthersn [ Wed Aug 31, 2011 11:54 pm ] |
| Post subject: | Bridge placement |
Any rules of thumb for bridge placement on a 25.5 scale length? I always seem to end up sharp and have to max out the saddles. I have double checked fingerboard scale (I have been using Stew Mac pre-slotted finger boards) and they are nut on. I usually set the saddles halfway and center that at 25.5 or 25 for PRS giving me a little wiggle room. It has not been a huge problem in the past because I had been using the Schaller roller bridge, but I'm using TonePros on the last few projects. P.S. I'm using LSR roller nuts and Earvana compensated nuts. Thanks in advance |
| Author: | JimO [ Thu Sep 01, 2011 2:37 pm ] |
| Post subject: | Re: Bridge placement |
Stewmac has a fret calculator that gives bridge positions for various bridge types. Very handy. http://www.stewmac.com/freeinfo/Frettin ... tcalc.html |
| Author: | Panthersn [ Thu Sep 01, 2011 6:31 pm ] |
Thanks for the link, my frets are exactly on and I found the note at the bottom of the calculation "Distance from the fretboard edge of the nut to center of forward-most mounting screw or pivot post." I guess this would put a tunomatic style about 3/8 - 1/2 past the magic 25.5 number. I guess I will just float the bridge under tensioned strings to that point and check the intonation. Nothing worse than spending a week carving a body to find out your bridge posts are off even a fraction of an inch
| Author: | Mustang_jt [ Fri Sep 02, 2011 2:08 pm ] |
I have found that the stew mac calculator is not always accurate for all the bridges, mainly with tremolo's. If I were you, I would put the neck on, and make a "dry run" before you drill anything. |
| Author: | jimmysux [ Mon Sep 05, 2011 12:36 am ] |
I have a very tried and true method. Measure from the nut to the 12th fret, then repeat that, go up 1/4" and place your bridge. |
