When to radius the fretboard? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=31650 |
Author: | jeff.scott [ Mon Mar 28, 2011 8:40 am ] |
Post subject: | When to radius the fretboard? |
Hello all, I just started to apply a radius block and sandpaper to my fretboard this morning ... first time build too. Maple is hard stuff to sand. ![]() Just wondering if I should cut the dimensions of the fingerboard first before sanding. Right now it is still a rectangular blank. It would seem there would be less sanding if I cut the fretboard first. ** just another note. I am taking all my measurements off a Les Paul Standard. This has binding on the fretboard. I won't be doing binding, so should I include the width of both bindings in my fretboard? Thanks again ... |
Author: | Chris Pile [ Mon Mar 28, 2011 10:02 am ] |
Post subject: | Re: When to radius the fretboard? |
Quote: Maple is hard stuff to sand. ![]() Try purpleheart sometime for some real fun. Quote: This has binding on the fretboard. I won't be doing binding, so should I include the width of both bindings in my fretboard? I would. |
Author: | JimO [ Mon Mar 28, 2011 11:07 am ] |
I did mine after it was cut to width and glued on. You ought to try Ipe for real fun and games. |
Author: | theguitarwhisperer [ Mon Mar 28, 2011 11:55 pm ] |
I have my necks fully shaped before I radius the fretboard to ensure that the fret plane is as regular as can be, sometimes the wood can move some after the back profile is shaped. |
Author: | Ian Cunningham [ Tue Mar 29, 2011 8:54 pm ] |
Hand planes are good for roughing it out ![]() |
Author: | John Coloccia [ Mon Apr 18, 2011 3:48 pm ] |
I'm a little late to this party, but I'll chime in anyhow. Radiusing the fingerboard is one of the last things I do to the neck, typically the last thing I do before gluing in the neck. I don't have any deep reason for doing it like this other than I like to keep things flat and square for as long as I possibly can. For me, building a guitar is an exercise in doing very simple operations in the right order because once a straight line is gone it's gone forever. I can't tell you how many times I've wished for a straight line I ended up shaping away, so just on general principle I keep it as square as I can for as long as I can unless I have a really good reason not to. |
Author: | Chris Pile [ Mon Apr 18, 2011 6:10 pm ] |
Quote: I don't have any deep reason for doing it like this other than I like to keep things flat and square for as long as I possibly can. For me, building a guitar is an exercise in doing very simple operations in the right order because once a straight line is gone it's gone forever. ^^^^^This is wise stuff, John.^^^^^ |
Author: | Mike Baker [ Mon Apr 18, 2011 11:33 pm ] |
John Coloccia wrote: I can't tell you how many times I've wished for a straight line I ended up shaping away, so just on general principle I keep it as square as I can for as long as I can unless I have a really good reason not to. I'm kinda in this camp, too. One of the reasons I wait until after the frets are installed before shaping the neck. I rout for the truss rod, install it, then attach the shaped and radiused fretboard to the neck blank. I like the thick neck blank with a flat surface behind the fretboard. It doesn't require a neck rest, and it is rock solid when hammering in the frets. I also think it helps avoid back bow from compression when fretting. After fretting, i shape the neck and glue it in. |
