It is currently Fri Jul 18, 2025 7:54 pm
 Post subject: Les Paul Build Question
PostPosted: Thu Dec 23, 2010 6:13 pm
I am planning a les paul build, yet have never done a les paul before. It is my understanding you have to angle the neck pocket about 4 degrees, do you also angle the pickup plane at 4 degrees? Or is it less? Also is the neck heel done at 4 degrees? Or is it also less?
And which way do you prefer to angle the pickup plane? I'm not sure how thick the cutaway horn starts at and tapers down to.
PostPosted: Thu Dec 23, 2010 6:32 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
In my sense, 4° is too much... I'd go with 2.5 or 3°. From what I know (and how I would do it), to higher part of the carved top (where sit the bridge and the pickups) is flat and parralel to the back, so, no angle. You angle the neck pocket, and well, you have to angle your heel too. If you put a 3° angle to your pocket, your heel will be at 93° (or 87°, depends the way you look).
That's how I would do it myself.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Dec 25, 2010 2:01 am
First name: shad
Last Name: peters
personally i like for the pickups to be parallel to the strings, therfore i angle the pockets and the pickup rings, otherwise one coil will be slightly hotter than than the other. may not make a difference but thats just my preference. also you only need angle the neck pocket, or the heel, but not both. if you put a 4 degree angle on the neck and the heel they are going to add constructively or destructively depending on what you do. you'll either end up with 8 degrees or 0 degrees.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Sat Dec 25, 2010 2:09 pm
Dangit I really need to buy one of those jigs.
PostPosted: Sat Dec 25, 2010 11:22 pm
First name: shad
Last Name: peters
Filippo Morelli wrote:
Chris, what's the difference jig-wise, insofar as what kind of pocket one is trying to cut?
Filippo
if you wanted to do a partial tenon like a les paul you could do one with a myka jig, but you would need to make a template piece that was the exact size as your tenon and then clamp that into the jig rather than the actual neck.. it would probably be a lot more work than its worth.
~shad peters
PostPosted: Sun Dec 26, 2010 12:56 am
The reason I would rather buy one is because I dont have the scrap wood for one. I dont have a planer to flatten out these boards, so by the time I got all the supplies and paid to get it all planed, I would probably just a little less than if I paid someone to make me one.
PostPosted: Sun Dec 26, 2010 11:16 pm
First name: shad
Last Name: peters
most lumber that you buy from the lumber yard is already plained, and sometimes jointed as well. but really i think you could go lowes and get everything you need for a myka style jig. half a sheet of plywood, a 6 foot 2x4 for the base a 1x2 for the top rails, and a hand full of nuts and bolts. i bet you could get all that you need to make a basic one for under 50 dollars, and i wouldnt think you could pay someone to make it for you for under 200.
~shad peters
