6-String Bass Nut File
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10123&t=29956
Author:  Zach Ehley [ Wed Nov 17, 2010 5:09 pm ]
Post subject:  6-String Bass Nut File
I've done a little looking and am having a hard time finding a nut file for a low B string on a 6-string bass (or 5-string). 0.135 For those of you who have built a 5-6 stringer, what have you used?
Author:  Ti-Roux [ Wed Nov 17, 2010 5:44 pm ]
Post subject:  Re: 6-String Bass Nut File
One thing you can do for bass nuts, because strings are quite large... You can begin the slot with some file (I like triangle one, it's precise). File till maybe a 64th before you desired depth. Then, take 1'' or 2 from a string of the desired gauge, then glue it (CA) on a wood stick. You have a cheap file, exactly the size you need. It don't cut that much, but it's perfect to do the final slot shaping.
Francis
Author:  theguitarwhisperer [ Wed Nov 17, 2010 9:33 pm ]
I use a .120 and roll it in the slot.
Author:  alan stassforth [ Wed Nov 17, 2010 10:58 pm ]
Or, use a round tapered jewelers file,
and stop when it's the same as the string gauge.
I like the other ideas too!
